what AFR's should I aim for
Old May 9, 2007 | 12:15 AM
tephra's Avatar
Hi Guys,
This weekend I will be installing my LC-1 and after that I will be tweaking my Hi Octane Fuel Map - what AFR's should I be aiming for?
I read that some people like 12.5 on spool, but others like low 11's
Any advice would be much appreciated.
Cheers
Dave
Old May 9, 2007 | 12:20 AM
moreryce's Avatar
all depeds wut u use the car for...
Old May 9, 2007 | 12:23 AM
tephra's Avatar
what do you mean?
Old May 9, 2007 | 03:08 AM
cij911's Avatar
Generally folks recommend an AFR ~11.5 and a bit leaner (high 11's / low 12's) under 3000 rpm...That said, it really depends on several factors including gas, timing, and boost...
Old May 9, 2007 | 03:52 AM
Mellon Racing's Avatar
I like 12's before boost and low 11's the rest of the pull.
Old May 9, 2007 | 08:07 AM
Jeff_Jeske's Avatar
I aim for 12:1 at spool to peak torque then have it fatten up to 11:1 till about 6k where I richen it up just a little more till the next shift.
Whatever gear I tune in I normally end up with mid to high 11's till 5k because of lean spool. Even with the lean condition I still rarely ever get knock so I'm keeping it the way it is.
Old May 9, 2007 | 08:31 AM
l2r99gst's Avatar
I do things a bit different than posted here. I like to have my AFR as rich as it's gonna get by peak torque and hold that AFR to redline. I don't like leaning it out at peak torque, which is the area that is most likely to knock.
For example, if I am aiming for 11.2:1, then I will get it 11.2:1 right before peak torque and hold it from there. Then, I use the timing to make adjustments. To each his own, though.
Eric
Old May 9, 2007 | 12:43 PM
C6C6CH3vo's Avatar
Use what ever AFR that you think is best, whatever you do make sure you have a real-time knock_sum display visible after changes
Old May 9, 2007 | 04:12 PM
tephra's Avatar
hrmm ok - so how does AFR affect torque?
11.5 seems pretty rich...
interesting stuff thou - thanks
Old May 9, 2007 | 04:20 PM
11.0 to 11.5 is ideal for pump gas, let your boost and timing make the power.
Old May 9, 2007 | 04:28 PM
lemmonhead's Avatar
ya I agree more adjustment in the timing is better. Gots to do both though to peak out your torque. Pretty lean on spoil up, I richen the hell out of it on top RPM and load though.
Old May 9, 2007 | 04:42 PM
mrfred's Avatar
11.5:1 would be rich for an NA car, but for a turbo car, the extra gasoline helps control combustion chamber temperatures and provides a bit of detonation resistance. You wouldn't want to go leaner than 12:1 at high load/boost, and even that is pretty lean.
Old May 9, 2007 | 05:05 PM
C6C6CH3vo's Avatar
that have resulted from timing advance.
Old May 9, 2007 | 05:07 PM
tephra's Avatar
but isn't it wrong to richen when you have advanced the timing too far? wouldn't it be better to retard the timing a bit??
Old May 9, 2007 | 05:28 PM
sekula's Avatar
i tune for high 11's for spool up but by redline i like to aim for low 11's since that will allow me to run more timing, which creates the power...and the richer you are, the more you can advance the timing....
