Help! EvoScan .99 2 byte load problem
Old May 15, 2007 | 06:01 PM
taenaive's Avatar
Recenlty I logged using new evoscan .99 and I did the 2 byte mod correctly.
Then, I found my 2 byte load was all screwed. am I supposed to edit the XML file for 2 byte load? How?
It seems that The XML file came with evoscan only loads 1 byte instead of 2 bytes from the data.xml file.
<DataListItem DataLog="N" Color="" Display="Load MUT 2Byte Mod" LogReference="LoadMUT2Byte" RequestID="00" RequestID2="01" Eval="0.3125x" Unit="units" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="500" ChartMin="0" ChartMax="500" ScalingFactor="1" Notes="" />
Old May 15, 2007 | 06:33 PM
RedV's Avatar
My line in the Data.xml file for 2-byte load looks like this...
<DataListItem DataLog="N" Color="" Display="Load MUT 2Byte Mod" LogReference="LoadMUT2Byte" RequestID="00" RequestID2="01" Eval="0.3125x" Unit="units" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="500" ChartMin="0" ChartMax="500" ScalingFactor="1" Notes=""/>
... and it works just fine, so it doesn't look like that's your problem. Did you add these settings...
<table name="2 byte load high bit" address="3EE86" category="Misc" type="1D" level="1" scaling="uint16" />
<table name="2 byte load low bit" address="3EE8A" category="Misc" type="1D" level="1" scaling="uint16" />
</rom>
...to the appropriate .xml file for your ECU then change these values...
Enter 27458 as the value for "2 byte load high bit".
Enter 27459 as the value for "2 byte load low bit".
...and flash the changes?
EDIT: These instructions are for the Evo IX .15 ECU. Since it looks like you've got a VIII I believe the address for 2-byte load is different.
Old May 15, 2007 | 06:37 PM
Ryu123's Avatar
There are two request ids on one line...RequestID and RequestID2.
Old May 15, 2007 | 07:33 PM
Pd1's Avatar
Pd1
Here's a "how-to" on 2 byte load:
https://www.evolutionm.net/forums/sh...d.php?t=261465
Old May 15, 2007 | 08:07 PM
TouringBubble's Avatar
The link above is for the IX v 15 ECU. If you used that tutorial, you need to track down the correct values for your VIII ECU.
Old May 15, 2007 | 09:08 PM
inco9nito99's Avatar
I noticed after doing this, my evoscan has a bit choppy delay before it reads new figures not a smooth transition when reading figures. Instead of an 'instant' change in values, it's acting as if after the change it reads in slow motion. Wonder why...
Old May 16, 2007 | 11:24 AM
taenaive's Avatar
Dang it! I put it in reversed order. Low and high byte address has been swapped.
Okay, Evo Scan is fine. the Rom mod was the problem. I can't wait to test this!
thanks guys
roni4g63
Nov 14, 2015 11:45 AM
Kaveeth
Sep 29, 2014 10:59 PM
Pitside
Apr 29, 2014 04:02 PM
mines5
Jun 18, 2013 09:49 AM
JohnBradley
Dec 9, 2007 07:55 AM
