Quick answer please... Ecuflash version
Old May 16, 2007 | 03:32 PM
bigric09's Avatar
Hey guys, i've searched but havent found a definitive answer... is ecuflash 1.3 working yet ? or is everyone still using 1.29 and 1.28 ? please let me know ... and if you can send me to a link to get the latest version... im going to openecu now... just hoping you guys can beat me to it
Old May 16, 2007 | 03:57 PM
bigric09's Avatar
bump bump
Old May 16, 2007 | 03:59 PM
kreionic's Avatar
I am still using 1.29
Old May 16, 2007 | 04:17 PM
TouringBubble's Avatar
I'm using 1.3 with no issues. Well, unless you try to change the map color schemes ... then you get about 200 error pop ups and the Subaru maps don't load correctly ... but who cares about Subaru maps, right?
Old May 16, 2007 | 04:20 PM
bigric09's Avatar
any word from the vista users ?
Old May 16, 2007 | 04:46 PM
bigric09's Avatar
anyone ?
Old May 16, 2007 | 05:53 PM
bigric09's Avatar
i tried 1.3, got the same error message i got before.... unable to connect to blah blah blah... installed 1.29, worked just fine.
Old May 16, 2007 | 06:33 PM
andenbre's Avatar
1.3 has been working fine for me on xp
Old May 17, 2007 | 02:28 AM
bigric09's Avatar
did you guys just install 1.3 and it worked ? or did you have to go back in and do something with drivers ?
Old May 17, 2007 | 02:51 AM
wrcwannabe's Avatar
I installed 1.3 after using 1.29a for several months. Did have issues, and not related to the drivers.
First backup your rommetafile directory from 1.29a and the backup001 directory
I did a full uninstall first, but the uninstall program does not remove the files and directories, even after a reboot. Reboot then remove the openecu directory by hand. I also uninstalled the FTDI drivers as they come bundled in 1.3 ( also 1.29a ) Perform the install and everything should install OK including the drivers. When you plug in the cable again it autodetects and finishes the driver install. Shows the openecu 1.3 cable in the box on the bottom line So no problem there
On to the problem
What happens is Ecuflash opens fine but cant find your ROM or definition properly, even after pasting in the files into \rommetafile etc and setting the options inside Ecuflash. Tells you unknown ROM definition and wants you to select from scratch, previous defintion or inherited from.... It will never work.
What is happening is it cant find the def and read files properly. Even after setting the options for the directories it still happens. You know you have the problem because when ecuflash opens it during the init it says O ROM....read..... on the third init line For some reason the backup files have to match the ones in current use. So here is the fix
You need to copy everything in the rometafile directories and subdirectories from ecuflash 1.3 to the backup001 directory backup001\rommetafile\
Then copy ALL the ROM def read files and .hex to the \ rom..\evo directory
Then double check to make sure you have the settings pointing to the correct directories. For Metafiles use \rommetafiles dont drill down farther
For the rom directory use \rommetafiles\mitsubishi\evo
This should fix it. During the init I then got 30 ROM.. read and it proceeded to open everything fine.
Milburn
Old May 17, 2007 | 03:29 AM
Chemwarrior's Avatar
I haven't had any problems with 1.3. It's read, tweaked, and reflashed just fine.
Old May 17, 2007 | 04:33 AM
Redline06's Avatar
Can anyone hook me up with a version besides.. 1.3 and 1.28..
Anybody got 1.29 or 1.27 that they can send me plz.. am begging you.. i need to try these versions b4 i blame the "unable to connect to vehicle interface" thingy on the tactrix cable..
Old May 17, 2007 | 07:17 AM
bigric09's Avatar
haha... if you go back and run the driver package, sometimes that helps. but, if you wanna try it out, when i get home i can shoot you 1.29 if someone doesnt beat me to it.
Old May 17, 2007 | 10:19 AM
iTune's Avatar
i got 1.29.906 if you need it.
CJ
