Cant remove Boost Cut..HELP
Old May 19, 2007 | 02:57 AM
fbikawi's Avatar
Originally Posted by burgers22
Hi
the boost limit tables on the ROM were all at stock, I've bumped them up to a flat 300, I've had no time to varify any other map, use at your own risk. Its also in a .rar format so you may need winrar to un zip it.
MB
sorry for being blind.
which "boost limit tables" u found all at stock and youve bumped them up??
i am comparing my rom i attached "4th modified....", to the rom u modifed "5th modified...", but i fail to find which tables u modified.
it is either i am blind or these tables are not defined in my xml so i cant see them.!!
thanks in advance
Old May 19, 2007 | 03:05 AM
burgers22's Avatar
Hi
I think your xml is screwed, have a look at my earlier post, I gave the map addresses in that. I'll send you an xml when I've cleaned mine up a little.
This is a fairly good xml for ROM ID 98640014
MB
File Type: zip
Old May 19, 2007 | 05:04 AM
fbikawi's Avatar
Hi
MB
yes the xml was wrongly defined.
now i can see the changes and even more tables.
i know that the map is very bad, i will start a new one and i will try it tommorow on the car.
i will let you know.
thanks for the great EVO 7 support u are doing here guys
Old May 19, 2007 | 05:30 AM
tephra's Avatar
your lucky you didn't totally screw something up with a broken XML
isnake
Apr 9, 2017 02:01 AM
b16a95eg
17
Sep 17, 2008 04:15 PM
alialper
Jan 23, 2008 08:06 AM
MaxBoost
23
Jun 9, 2003 12:48 AM
