Timing map with 280 cams...
Old May 21, 2007 | 03:08 PM
A418t81's Avatar
Anthony, see my new post I just made:
https://www.evolutionm.net/forums/sh...d.php?t=272246
Old May 21, 2007 | 03:19 PM
TTP Engineering's Avatar
Couple things.
Many have neglected to notice you are running BC 280's, not HKS, GSC or Compcams.
They have different lift and actual duration than the rest of the cams.
No one should be able to directly compare their ignition timing map unless they are running the BC 280 cams.
Furthermore, without offense intended. Your timing map is garbage. 10* from 5500+? That is too much, too early.
Spark plugs heat range, cam gear degreeing, valvetrain status should also be taken into account.
Old Oct 14, 2012 | 08:49 AM
Howulikemyevo's Avatar
I also have bc 280 cam. If anyone can help me to set at the right degree too please. Pm me!!!
tbaird58
Feb 21, 2017 06:13 PM
evo8vz
Jan 12, 2016 12:56 PM
Darksun280
Evo X Dyno Results
22
Jul 7, 2013 08:25 PM
okevolutionVIII
21
Feb 25, 2011 06:52 AM
Yaroslav
21
Dec 15, 2005 08:34 AM
