my 1st log, 3rd gear wot
comparing to a few other logs iv seen on here, mine doesnt look too bad, any comments/views appriciated
thanks
http://www.mediafire.com/?axl0ndx2xym
thanks
you are only running 1 degree of timing at peak torque, not that great - but not bad either.
why didn't you log one of the most important factors in datalogging, knock sum?
that is how we know if your tune is behaving properly.
sorry guys my bad, thought i did, totally forgot that i didnt tick the box, heres an updated 3rd gear WOT with knock sum, its not to bad doesnt go higher than 2 and only knocked three times during the 3rd gear wot log below:
http://www.mediafire.com/?f9mszynz4eb
I'll leave that for the real pros
. It looks ok to me though...what octane fuel? Some people (as joshesh said above) will think the 1 at peak torque is kinda tame (they did when I had mine at 1
im running 99 RON which is the same as 93 in the US i think.
the map was actually done by one of the countrys top mappers, sam aka the dentist so i hope its as good as he potrays his work to be.
If you disable all of the useless items being logged, you'll get a much faster logging rate. I have only the essentials enabled (rpm, tps, boost, load, knock sum, ign advance, WGDC, air temp, coolant temp, IPW), and I get 110 entries in a 3rd gear pull.
Mr. Evo IX
34
Apr 3, 2008 09:39 AM
