HOW TO - Control boost using ECUFLash and 3 port GM boost solenoid
Old Oct 23, 2018, 08:19 PM
  #556
Raptord's Avatar
You can log Boost Error in Evoscan, then add a column to the log in Excel afterwards where you would subtract Boost Error from the logged boost. That should give you an idea of what the ECU is (or think it is) targeting. Note that I think Boost Error only has a +/- 3psi range if I remember correctly, so you'll have to be in the right ballpark for it to work. However if boost error stays pinned at -3 the whole time for example, then you'd know the ECU is targeting a higher boost, so you can adjust the desired boost tables to eventually reach the right number.
Old Oct 24, 2018, 07:32 AM
  #557
MR Turco's Avatar
Understood and logging that. Hoping i can narrow down why there is a delta. That is how i'm working around it but i would like to be more precise or understand what is influencing the discrepancy.
Old Oct 28, 2018, 01:44 PM
  #558
Evo_Jay's Avatar
Originally Posted by MR Turco
So a couple of oddities i haven't seen before. I've only deeply tuned this on a 9 but working to get this setup on a buddy's car (05 8) using PSI controlled boost on 9653 V7 rom w/ OMNI 4 bar and stock maf.
  1. On the Boost desired PSI table - minimum value is 7.4. Not an issue but it's odd.
  2. I am targeting 30psi but i notice i am getting boost error correction at <30 PSI - starting around 2-3psi lower than expected - AEM boost gauge is showing under target PSIa as well.
    • Can't tell if logs aren't granular enough or if the ecu is attempting a different target
    • Is there a way to log what my boost target is - what the ECU thinks it is
I ended up turning off all downward correction including IAT just to get a boost curve set. But trying to understand the discrepancy since I would like to enable error correction. I can workaround most of this I just dont recall seeing this years ago when i tuned this, it was very on par.
Thoughts?
Thanks in advance
-Mike
Check the map sensor settings for the boost control tables. Thats most likely your issue.
MR Turco (Oct 28, 2018)
Old Oct 28, 2018, 06:07 PM
  #559
MR Turco's Avatar
YUPPPPPPPPPPPP the scaling is set to OMNI 4 bar Adjusted, setting it back to the omni 4bar non-adjsuted makes WAY more sense. Thanks!
Old Nov 1, 2018, 10:01 AM
  #560
Evo_Jay's Avatar
No problem.
Evo_Jay
Feb 18, 2016 10:04 AM
bluewaterDEMON
Lancer How Tos / Installations
Sep 24, 2007 11:42 AM
ArchieBabes
Sep 19, 2006 02:46 PM
vegasboy301
Jul 11, 2006 01:14 AM
vegasboy301
May 11, 2006 07:38 PM
Quick Reply: HOW TO - Control boost using ECUFLash and 3 port GM boost solenoid
