Mitsulogger use with a wideband???
Old Jun 14, 2007 | 02:21 PM
brobards's Avatar
Can the ecuflash/mitsulogger be used to log a wideband O2 sensor? If so how would you need to wire the wideband in?
Old Jun 14, 2007 | 02:42 PM
mchuang's Avatar
The mitsulogger can log a wideband. Ecuflash is a seperate program and cannot log a wideband. You will have to search or look on www.aktivematrix.com to see exactly which ones are supported. I know innovate, zeintronix, and turboxs are supported for sure.
Old Jun 14, 2007 | 07:12 PM
wrcwannabe's Avatar
See mrchuang's reply. For wiring in the wideband the manufacturer has the instructions. I use the LC-1 from Innovate www.tuneyourengine.com
Huge forum on how to wire it up and use Logworks to datalog. Once wired in to a serial port, you can use Mitsulogger and Evoscan or Logworks
You can use Ecuflash to reflash your ECu ( tune it ) , but will need a datalogger to check to see how the changes are affecting the way the engines runs. useful data loggers are : Logworks, Evoscan, mitsulogger first and last are free, Evoscan cost $25 IIRC.
Evoscan and Mitsulogger will work with Zeitronics , i beleive, maybe a few others. Check before you buy
Milburn
Old Jun 14, 2007 | 08:17 PM
nothere's Avatar
the nut of it is you have a usb ecuflash cable and a serial cable from your wideband controller. the logger mingles the two data sources.
neither evoscan or mitsulogger currently allow multiple innovate inputs, a single wideband yes, but not if you have other innovate inputs in the serial stream. fortunately logworks will, though the current version 3 beta is for those who can deal with pain. version 2 is for the layman till they debug 3.
did I cover some of the bases?
mines5
Jun 18, 2013 09:49 AM
yikez
Sep 13, 2008 08:00 PM
ekizenbe
Jul 30, 2008 08:52 PM
BABYEVO 8
Dec 7, 2007 09:46 AM
MalibuJack
Feb 1, 2007 10:46 AM
