serial to usb driver (aem wideband)
Old Sep 9, 2008 | 10:11 AM
yikez's Avatar
Exclamation serial to usb driver (aem wideband)
I am trying to log my AEM wideband. It used to work in the past but after i got my laptop formatted there seems to be a conflict somewhere..
i have already made the usb to serial and it used to work .. but now i just cant log it. in the device manager it shows there is a conflict. And it does not show the location of the com port (displays as 0).
In mitsulogger i can only choose 3 or 4 com port but none seems to work..
can someone provide me with the correct driver or how to sort out my problem?
Thanks,
Bader
Old Sep 9, 2008 | 10:16 AM
TeStUdO's Avatar
What serial to USB cable are you using?
Old Sep 9, 2008 | 10:20 AM
yikez's Avatar
RS232 serial to usb ... it used to work before i formated my laptop.
Old Sep 9, 2008 | 10:22 AM
TeStUdO's Avatar
Did you make it yourself, or buy one that was premade?
Old Sep 9, 2008 | 10:33 AM
yikez's Avatar
A friend made it for me. Prior to formating, I had the same issue, but I was missing the driver and when I found the correct one it worked. Now I can't seem to source the driver or fix the conflict.
Old Sep 9, 2008 | 10:34 AM
lilman8403's Avatar
i had the same problem but then formatted the laptop for it then it worked fine. It is a little odd that is didn't work out of the box.
Old Sep 9, 2008 | 10:47 AM
TeStUdO's Avatar
See if this driver works:
http://www.dynexproducts.com/skins/S...B9_Drivers.zip
Try logging with Hyper Terminal and see if you can figure the problem out there.
Old Sep 9, 2008 | 12:08 PM
yikez's Avatar
Ill download it now and see if it works!
Old Sep 11, 2008 | 12:07 PM
yikez's Avatar
still doesnt work :/
on the computer, in settings - hardware - devices, it shows as an exclaimation mark (conflict)...
the only thing changed was me formatting the laptop ... it shows as driver malfunction .....
any other suggestions ..
Old Sep 11, 2008 | 12:17 PM
TeStUdO's Avatar
Damn, that driver was a shot in the dark. Try going in device manager, click on the "Ports" and try updating the driver. If that doesn't work, try removing the driver and installing it agian.
Old Sep 11, 2008 | 12:20 PM
ElectricEvoIX's Avatar
it should definately be the driver. I had the same issue with mine till I had to source an install CD. Granted I bought mine from the store but I got the same error messages as the OP till I located the drivers for it.
Old Sep 11, 2008 | 02:09 PM
yikez's Avatar
Where did u locate the drivers from? I don't have the CD that came with it.
Old Sep 11, 2008 | 03:49 PM
did you buy your USB to serial? or was it made by someone else? I made the hook up for the RS232 connection but bought the USB to serial from best buy.
Old Sep 11, 2008 | 05:31 PM
yikez's Avatar
It was made by someone else. But like I mentioned before, it used to log my wideband prior to formating. It shows as a conflict in device manager now though.
Someone must have the driver...
Old Sep 11, 2008 | 07:05 PM
well it all depends on what materials he used to make it. I could try to locate my drivers and send them to you and see if it works
