Fuel-trim mid - Which Fuel Load cell used?
Old Jun 16, 2007 | 07:11 AM
Oracle1's Avatar
In mitsulogger, which fuel load cells are used for the mid fuel trim? (I assume cruise?)
TIA
Old Jun 16, 2007 | 01:33 PM
Oracle1's Avatar
Old Jun 16, 2007 | 03:03 PM
TouringBubble's Avatar
From what I understand, trims aren't connected to any cell value in the fuel map. They only affect closed loop, which should aim to hit 14.7:1 all of the time. The trims are just slight adjustments to the fuel to hit that 14.7:1 ratio.
Old Jun 16, 2007 | 11:24 PM
tephra's Avatar
yup...
Old Jun 17, 2007 | 12:10 PM
chmodlf's Avatar
according to malibujack mid is closed loop at light cruise (low rpm).
Old Jun 17, 2007 | 12:40 PM
Ph3n1x's Avatar
When in Closed loop the ECU relies on the o2 Feedback to adjust fuel being delivered to maintain stoich 14.7 Afrs and not the Fuel map.
Once you are not exceeding +30/-30 from the 100 point (Evoscan) or +10/-10 (Mistulogger), you have nothing really to worry about since the ECU adjusts depending on a host of factors such as whether or not the AC is on etc.
Old Jun 17, 2007 | 12:49 PM
Oracle1's Avatar
thanks...
