MacLogger 2.0
Old Nov 22, 2007 | 09:48 AM
  #31
donour's Avatar
Originally Posted by Vigman
Hi Donour!
Have you worked on a new version?
(remember my mail with double request ! :-)
Still can't connect....
I remember. I do have a new version with a few kinks worked out. Unfortunately, OS X Leopard broke a few things and my build system doesn't work right now. Do you want to try building it yourself? The CVS tree is publicly accessable.
donour
Old Dec 24, 2007 | 01:49 PM
  #32
donour's Avatar
I just posted a new build this morning.
Version 2.01 is a bugfix release only. An official leopard build is available for download.
d
Old Feb 1, 2008 | 01:17 AM
  #33
bzzbee2's Avatar
This looks awesome. My cable will be arriving by next wed. Thanks for doing this.
Old Feb 1, 2008 | 01:29 PM
  #34
donour's Avatar
Sure thing.
d
Old Feb 1, 2008 | 05:13 PM
  #35
Inprogress's Avatar
Is there any support for widebands yet? Specifically the AEM? And what about JDM MAP and 2-byte load?
thanks a lot donour for opening up this possibility.
Old Feb 1, 2008 | 05:21 PM
  #36
donour's Avatar
All of these things are possible, but I just haven't had time to add more functionality. Full source code is available if any programmers want to take a hack at it.
In a related note, pyXede, one of my other programs, can read afr/lambda values from the Xede's 5v input. So, if you have one of those...
donour
Old Feb 6, 2008 | 09:46 PM
  #37
bzzbee2's Avatar
Got my cable... all is working well on my macbook. The first 5 times i connected it timed out pretty dang fast. after that all is well. Since im a noob to this whole thing, im not sure what all the items are that this is logging. is there a list somewhere that breaks down what all these items are?
Old Feb 6, 2008 | 10:05 PM
  #38
Wicked E's Avatar
This is awesome!!!
Old Feb 7, 2008 | 09:22 AM
  #39
donour's Avatar
Sometimes it times out. I haven't figured out why, but I've never had it do it 5 times in a row. Does it still timeout for you?
If you have questions about the meaning of a logged datum, just post here and we'll explain what it is. For example TPS is the throttle position sensor.
d
Old Feb 7, 2008 | 09:31 PM
  #40
bzzbee2's Avatar
Each time it times out now it takes longer and longer to do it. It was only those first runs that i had problems with. Since then its worked flawlessly.
Old Feb 8, 2008 | 08:12 PM
  #41
ashumo's Avatar
Any updates on letting it work using the same driver as EcuFlash since im removing the driver for MacLogger to use EcuFlash? OS X 10.4.11
Old Feb 8, 2008 | 08:26 PM
  #42
donour's Avatar
Not yet. It's a total pain, I agree. I have written the little bit of code to show it works and how to do the logging on OSX. However, a fairly hefty bit of the code will need to be rewritten. I just haven't had much time.
For those of you who don't know. I'm working on my PhD right now. All the time I don't spend on that, I'm racing. Unfortunately, this is one of those projects that only get a few hours every couple of months.
So I'll put out a call again. And mac programmers want to take a stab at it? Most of the heavy lifting is done. What remains is taking working code and porting it to a new interface.
d
Old Mar 6, 2008 | 07:10 PM
  #43
bzzbee2's Avatar
So how do i remove the driver from my mac to use ecu flash? Although its a pain i really dont mind. But i would like to use ECUflash...
Old Mar 6, 2008 | 08:32 PM
  #44
donour's Avatar
Remove the libftdi system extension.
d
Old Mar 6, 2008 | 09:47 PM
  #45
VictoryEVO's Avatar
Thx will give it a go
