MacLogger 2.0
Old Jul 5, 2007 | 03:42 PM
donour's Avatar
MacLogger 2.0
I'm happy to announce the full release of MacLogger 2.0, my OS X mut logging tool (based on libmut). The latest release is almost completely new (i.e. about 90% of the code has never been seen outside my garage).
It's been prettied up to look like this
Longtime mac users will find it behaves just like any other mac application, not like the ports of Unix apps that I'm used to writing.
The blurb on the website reads:
"I'm going to go out on a limb here, and not preface this release with any special disclaimer. I believe it is fully ready for production use by the general public. It does, however, lack two features folks may be interested in. It does not support multibyte requests and it does not support requests that are computed as the result of other requests. The latter is highly nontrivial to implement, but will be available in service releases. Enjoy!"
And here's the readme, included in the distribution:
MacLogger is a tool to log Engine Control Unit data using the MUT III protocol used by Mitsubishi diagnostic tools. MacLogger is built on LIBMUT and support the Tactrix OpenPort 1.3M Cable.
MacLogger is a Universal Application, meaning it supports both the PowerPC and Intel x86 variants of Macintosh OS X. It requires a modified OS X driver for the FTDI chip, used in the OpenPort cable. A modified version of the driver is included as well. The driver is also Universal.
To use MacLogger, simply install the FTDIUSBSerialDriver.pkg then open the MacLogger application. The OpenPort cable will appear in the ports list of MacLogger with the name 'cu.usbserial-XXXXXXX", where XXXXXXX is the serial number if your cable.
As always, the build and full source are available here:
http://www.cs.unm.edu/~donour/cars/libmut/
cheers
d
Old Jul 5, 2007 | 10:23 PM
mrfred's Avatar
Cool. I may have to give it a try on one of my macs. Does your program do any averaging of the raw data read from the ECU?
Old Jul 5, 2007 | 11:38 PM
curisu's Avatar
This is awesome donour! Much appreciated. I'll give it a whirl on my drive to work tomorrow.
Old Jul 6, 2007 | 05:01 AM
TouringBubble's Avatar
Any chance you have a version of this for logging Subarus? I've got a friend who has nothing but Macs and needs to log his STi.
Old Jul 6, 2007 | 05:55 AM
donour's Avatar
As in displaying the current samplerate? No, but i've aready implemented that feature a couple of times, so I can just add it back in if people want it. You can't do anything to change it, so I didn't bother displaying it.
d
If somebody were to provide a good, free SSM library, sure. I don't own a subaru, so I have nowhere to test if I write my own library.
d
Old Jul 6, 2007 | 06:04 AM
scorke's Avatar
Your the man!!!! Now I just have to man up and strap my MBP to the other seat for some fun runs.... utoh...
Scorke
Old Jul 6, 2007 | 06:31 AM
juyanith's Avatar
You know, if apple didn't try to tie me to their hardware, I'd probably buy the OS. Maybe if I can find a cheap mac laptop I'll give it a try but until then I'm using linux. Thanks for the work donour, I had fun looking at the libmut code and really appreciate you releasing this stuff as open source.
Would you care to elaborate on your "multibyte requests" and "requests that are computed as the result of other requests" comments? I see in the mut_log.c example that MUTLOAD computes load from IPW, etc. Is that not what you mean by the second comment? I'm just curious.
Old Jul 6, 2007 | 08:38 AM
donour's Avatar
If you're willing to do the testing for a linux build, i'm more than happy to make the necessary changes. Email me at the address listed in the distribution.
Specifically, I was thinking about two byte load and computer values such as power, current gear, and, as you observed, calculated load.
d
Old Jul 6, 2007 | 08:46 AM
DonMitsu's Avatar
Where are you guys getting USB cables to connect to the ODBII conector?
Old Jul 6, 2007 | 08:49 AM
donour's Avatar
We're using the tactrix cable which has been out for quite a while. It's the same one used with EcuFlash.
donour
Old Jul 6, 2007 | 10:10 AM
spooch's Avatar
il be trying this in a couple weeks when my tactrix cable comes in
Old Jul 6, 2007 | 10:33 AM
MalibuJack's Avatar
For logging you can also try to use an FTDI based VAG-COM KKL cable, it doesn't have a special driver required for the FTDI chip, and my variants of linux immediately sees it as a serial device.
Let me preface this with: I know the vag-com FTDI cable works with MUT logging using Mitsulogger, however its windows based. There is no reason why it shouldn't work in this case either.
If you don't intend to flash the ECU, or just can't until a good build of ECUFlash becomes available for the MAC and Linux, then this cable is an option. Typically their available for $20 including shipping.
If you want to flash, or want the real deal, then the Tactrix cable is the only way to go.
Old Sep 10, 2007 | 05:26 PM
evo420's Avatar
Question
so has any one tried this. how well does it work ? ??? own a home pc but only have access to a mac laptop and need to log to get a good eflash tune. or should i just bite the bullit and buy a pc laptop?? also does this log multiple items such as.
TPS
RPM
TimingAdv
O2Sensor
InjPulseWidth
Battery
LoadCalc)
KnockSum
AFRMAP
Wideband A/F Ratio
Old Sep 10, 2007 | 06:57 PM
donour's Avatar
Originally Posted by evo420
TPS
RPM
TimingAdv
O2Sensor
InjPulseWidth
Battery
yes,yes,yes,yes,yes
LoadCalc)
NO
KnockSum
AFRMAP
yes yes
Wideband A/F Ratio
maybe...
d
Old Sep 10, 2007 | 07:53 PM
justboosted02's Avatar
Need Innovate Wideband Support!!!!!!!!!!
