Tune for Walbro
Old Jul 8, 2007 | 02:06 PM
JordanS4's Avatar
Tune for Walbro
I am currently tuned for the following mods
IX MR
280's
Denatured Alcohol
TBE with HFC
MBC @ 28 psi spike
What needs to be tweaked to get the Walbro in the car and running well enough until I get a tune? If I just drop it in will it run fine, just rich?
Thanks
Old Jul 8, 2007 | 02:10 PM
JakeTheVIII's Avatar
Should run the same and be fine at least until you get it tuned.
Old Jul 8, 2007 | 02:14 PM
kinloch99's Avatar
yup will run fine
Old Jul 10, 2007 | 02:07 PM
Usedcarfinders's Avatar
itll be fine!
Old Jul 10, 2007 | 02:42 PM
Mr. Evo IX's Avatar
It might run a little rich on the top end if it was having trouble getting fuel before but it will be fine.
Old Jul 10, 2007 | 02:53 PM
deegaw11's Avatar
so u was running high boost with all those mods on your car and no fp and it was fine? damn what the hell do i need a fp for with hardly any mods.
Old Jul 10, 2007 | 02:56 PM
rcheung's Avatar
You don't. The evo 9's came with a much better fuel pump than the evo 8's did.
Old Jul 17, 2007 | 08:40 PM
SophieSleeps's Avatar
I logged absolutely no difference after I dropped a walbro in my car and another IX that I tuned.
Old Jul 19, 2007 | 11:04 PM
CheesyEVO's Avatar
Tune so not to ruin...
Definitely tune after Mod...on 8 needed to get FP on 9 FP was OK on CAI and TBE ...until injectors. Tune / Flash cleans up even stock to make more RWHP!!!
Old Jul 20, 2007 | 09:11 AM
Ph3n1x's Avatar
A Retune is not needed because of the Walbro persay...a Retune is done for an adjustment of air/fuel ratio dependent on factors such as boost, timing etc.
Old Jul 20, 2007 | 11:34 AM
Originally Posted by Phenix_fyah
A Retune is not needed for the Walbro persay...what is needed is an adjustment of air/fuel ratio dependent on factors such as boost, timing etc.
I think your definition of retune is different than most of ours.
If you're touching the map and adjusting AFR you are re-tuning the car.
The IX doesn't need a retune or any adjustment after installing the walbro.
AFR's are the same given a fairly stock car.
Old Jul 20, 2007 | 11:40 AM
Ph3n1x's Avatar
Sorry wrong choice of words....
Old Jul 20, 2007 | 11:42 AM
Kimbo!!!
Old Oct 29, 2007 | 01:46 PM
Thoe99's Avatar
So if your tune is spot on for an Evo8, and all you're doing is upgrading to Walbro 255, no re-tune is needed?
Old Oct 29, 2007 | 09:15 PM
coolguycooz's Avatar
Actually no, for an 8 you will need a retune. I just did a walbro 255 on my 8.
my AFR went from an 11.8 (maxing out the old pump 105% IDC) to a 9.9:1 at one point thats almost 2 full points richer. EVO 8 will requier a retune for the walbro 255. Unless you want a boggy flat 10:1 AFR
