Help with Funky AFR
Old Jul 17, 2007 | 07:17 AM
  #61
nj1266's Avatar
Originally Posted by mrfred
How did you disable lean spool?
I followed your directions. If you remember, there was a thread where you told me how to define the tables and how to display them in rpm. I set both enable and disable to 2500 rpm.
But it is not relevant to the problem, since the car exhibited the same problem with a stock flash w/o ANY new maps defined. I basically used stock xml files and a stock rom to flash the ECU and the problem persisted.
Old Jul 17, 2007 | 07:21 AM
  #62
nj1266's Avatar
Originally Posted by TouringBubble
Actually, I was having this issue while tuning. I had it nailed down at 11.5 till around 5500. I made a couple of changes and logged in the exact same location not 20 min later and the AFR read 10.8. Confused, I went back around and logged again ... 11.5. the car was at normal temps the entire time, boost an load were nearly identical as well.
I have not read all the way back ... are you using Innovate for WBO2?
With my car, once the AFR became rich in the 3000-6000 rpm section it stayed rich. It did not revert back to the way it used to be until I flashed the ECU again.
I am using an innovate LM-1.
  #63
Tuner@Swift's Avatar
What are you using for an air filter?
Old Jul 17, 2007 | 07:23 AM
  #64
nj1266's Avatar
I am using a K&N drop-in filter. But the problem was happening even when I had the stock panel filter.
Old Jul 17, 2007 | 07:26 AM
  #65
I still think its a fuel trim issue. Do you have OBD scantech sfotware? Check the fuel trims through that after a few drive cycles.
Old Jul 17, 2007 | 07:29 AM
  #66
TouringBubble's Avatar
I'd suggest asking Kalus if he might have an explanation. Is this happening in Log Works? I was using EvoScan when it happened to me.
Old Jul 17, 2007 | 07:50 AM
  #67
nj1266's Avatar
Where do I get the OBD scantech software from? Let us say that it is a fuel trim issue. How do I go about fixing that?
BTW, I have a code reader/clearer. I hooked it up after the car exhibited the problem I am talking about and told it to erase all codes even though there were none. Then I went logging and the problem persisted.
Old Jul 17, 2007 | 07:54 AM
  #68
nj1266's Avatar
I logged with Evoscan and got the same results as Logworks.
Old Jul 17, 2007 | 08:14 AM
  #69
Pd1's Avatar
Pd1
Where do I get the OBD scantech software from?.
http://www.aktivematrix.com/forum/dl...ile&file_id=27
Old Jul 17, 2007 | 09:40 AM
  #70
roger smith's Avatar
I read through the entire thread. I was thinking it was weather or elevation but now I believe it's the long-term fuel trim too. Your AFR went back to normal after you flashed - that cleared the fuel trim too. I don't think clearing trouble codes clears fuel trims. The ECU either has to lose power or be reset (reflashed).
That's the only thing that would change your fueling after a long period of driving. It's where your car wants to settle so I'd try fixing the trim problem or tuning to where it settles like you said you have (your temporary work-around).
Old Jul 17, 2007 | 04:20 PM
  #71
Jorge T's Avatar
afaik clearing codes resets all trims to pre readiness state, if not disconnecting power to the ECU will erase all adaptation.
Aren't trims are a result? Why would trims be off with stock injectors and stock injector parameters? What is giving the ECU a signal to get the trims out of whack? Would it be a faulty O2 sensor?
Old Jul 17, 2007 | 06:08 PM
  #72
nj1266's Avatar
I have logged fuel trim with MJ's Mitsulogger for an extended period of time (30-40 minutes) and I got:
FuelTrim_Low: 0
FuelTrim_Mid: peaked @ 9, but stayed steady @ 7
FuelTrim_High: 0
The only trim that is off is the mid. Would that cause this problem? What should I do to get the FuelTrim_Mid to read 0?
Old Jul 17, 2007 | 10:12 PM
  #73
RazorLab's Avatar
Nj, what was the 02 feedback at? That is your short trim
Old Jul 17, 2007 | 10:26 PM
  #74
nj1266's Avatar
I did not log that. I will log it tomorrow on my way to work and get back to you.
Old Jul 17, 2007 | 10:44 PM
  #75
nj1266's Avatar
Actually, I checked the logs and I did log the O2 feedback. The O2 feedback goes as high as 21 on my car and as low as -6. Most of the time it is in the teens. I hope that is the problem so I can start solving it.
