Timing : Fuel?
Old Jul 25, 2007 | 07:14 PM
  #46
C6C6CH3vo's Avatar
Originally Posted by Mellon
It's been my experience that cars with a leaner AFR and less timing are less consistent for races with extended periods.
Good point.
Just run less boost and keep the tune reasonable. Adding fuel is similar to less boost. It's the power that will heat things up too quick, especially overtimed.
But your absolutely right - I would never run WOT extended as it is now, but that is not what I use the car for - it's used for going to work really fast and several 1/8 mile runs each Fall
Old Jul 25, 2007 | 10:05 PM
  #47
EVO8emUp's Avatar
So right now, my car is pretty much stock with the exception of the 3" TBE and K&N drop-in filter. However, I'm seeing as high as 3 counts of knock (knock sum)
amd it's still on the stock ROM. Can this be attributed to the increased airflow from the exhaust/Filter?
I want to make sure everything is in proper working order before having it reflashed. So another question is... what constitutes too high of a knock count.
Doesn't the ECU start to pull timing around 3 counts?
Old Jul 26, 2007 | 01:13 AM
  #48
C6C6CH3vo's Avatar
That is attributed to the fuel you are using, those mods may even make it knock less unless your boost and hp increased
Boostin Perform
Evo 'For Sale' Services
May 12, 2017 08:28 AM
Boostin Perform
EvoX 'For Sale' Services
May 12, 2017 08:27 AM
Tw3NTy0n3
Feb 17, 2017 08:57 PM
Dynotech Tuning
39
Dec 3, 2016 11:04 AM
jmelocik
27
May 31, 2010 01:54 PM
