Car Down On Power Big Time
Old Jul 28, 2007 | 10:27 AM
dan l's Avatar
How high did you boost leak test. You need to test to at least 30psi on your car and bleed down should be better than 1psi per second.
With no boost leak if your target AFR is 11 you should be running about 12's. What is your target AFR and what is your actual AFR ad 4000, 5000, 6000, and 7000 rpm's respectively on a third gear pull.
Old Jul 28, 2007 | 12:43 PM
fid's Avatar
fid
I boost leak tested with fabbed up coupler and tire valve to 30psi and just listened for leaks. I didn't put the gauge on it unfrotunately.
On a 3rd gear pull target to actual is as follows:
4000:9.0---11.7
5000:9.0---11.7
6000:9.2---11.6
7000:9.2---11.3
Here are two logs, the 1st is a straight 3rd gear pull the 2nd (slightly uphill pull) is a 3rd to 4th gear pull...
File Type: txt
File Type: txt
Old Jul 28, 2007 | 12:57 PM
burgers22's Avatar
Looks like theres more to come once you get those AFRs a tad leaner.
MB
Old Jul 28, 2007 | 01:54 PM
EVO8LTW's Avatar
Was the 3rd gear pull on level ground? I was just comparing the acceleration rate to my recent logs (IATs about 93 degrees, which is close to yours) and it seems like your car is slower by a significant amount above 5500 rpm, which I think probably shouldn't be the case given your mods. My car may be 150 lbs. lighter than yours since I have an 04 RS, but I don't think that fully accounts for the difference. Also, my car is tuned much richer than yours with AFRs in the 11.3-11.5 range. I have a white rabbit VIII turbo, which should be 20 whp short of your green, and am tuning on 93 oct at 22 psi peak boost.
Not trying to knock your car, but just trying to give you a reference point.
Your car:
[deleted to conserve space -- see next post]
My car:
Old Jul 28, 2007 | 02:15 PM
EVO8LTW's Avatar
Actually, I just noticed how weak your timing is. That's the difference.
Compare mine:
ET---RPM---Timing Advance
0.00 4000 4
0.23 4094 3
0.34 4219 4
0.47 4344 5
0.58 4438 5
0.69 4594 5
0.80 4656 5
0.91 4781 6
1.03 4906 6
1.16 5000 6
1.25 5094 6
1.36 5250 7
1.47 5313 7
1.58 5438 8
1.69 5531 8
1.80 5625 8
1.91 5750 9
2.02 5844 9
2.12 5938 9
2.23 6063 9
2.34 6156 10
2.45 6250 11
2.56 6344 11
2.69 6438 12
2.80 6563 12
2.91 6625 13
3.02 6750 14
3.12 6844 15
3.23 6906 15
3.34 7031 16
3.45 7125 17
3.56 7188 18
3.69 7281 18
3.80 7375 18
To yours:
0 4000 4
0.09 4063 2
0.2 4156 -1
0.31 4219 -3
0.42 4313 -4
0.51 4375 -3
0.62 4500 -2
0.73 4594 1
0.84 4656 1
0.95 4750 0
1.04 4875 0
1.15 4969 0
1.26 5031 0
1.37 5156 1
1.46 5219 1
1.57 5313 1
1.68 5406 1
1.79 5500 1
1.89 5594 0
2 5625 0
2.1 5750 0
2.21 5813 2
2.32 5906 2
2.43 6031 3
2.54 6063 3
2.65 6156 4
2.76 6250 4
2.87 6313 4
2.96 6438 7
3.07 6500 7
3.18 6563 7
3.29 6688 8
3.4 6750 8
3.51 6813 8
3.62 6906 9
3.71 6969 9
3.82 7031 10
3.93 7125 10
4.03 7188 10
4.14 7250 10
4.25 7313 10
4.34 7375 10
Old Jul 28, 2007 | 02:18 PM
fid's Avatar
fid
No offense taken at all. Yeah it looks like the car is a whole .5 seconds slower then yours to redline and that is just one shift. Did you take that comparison from my most recent log I posted?
Old Jul 28, 2007 | 02:21 PM
C6C6CH3vo's Avatar
Originally Posted by fid
What do you think of the airflow and IPW now?
Looks fine, boost would be higher for that airflow on my car, but the IX turbo pumps more volume than my VIII turbo- maybe thats why.
If you don't feel the difference then your nervous system is fried. You ran 0 - 60mph in 4.5 seconds with two 0.6 second shifts on the clock.
Your timing is fine, put some racegas in there lean to 12.2, keep timing the same, increase the boost and 11's await you
EVO8LTW's Avatar
Yes, I pulled it from your most recently posted 23 psi 3rd gear log.
Old Jul 28, 2007 | 02:29 PM
C6C6CH3vo's Avatar
Compare mine:
0.00 4000 4
0.23 4094 3
0.34 4219 4
0.47 4344 5
0.58 4438 5
0.69 4594 5
0.80 4656 5
0.91 4781 6
1.03 4906 6
1.16 5000 6
1.25 5094 6
1.36 5250 7
1.47 5313 7
1.58 5438 8
1.69 5531 8
1.80 5625 8
1.91 5750 9
2.02 5844 9
2.12 5938 9
2.23 6063 9
2.34 6156 10
2.45 6250 11
2.56 6344 11
2.69 6438 12
2.80 6563 12
2.91 6625 13
3.02 6750 14
3.12 6844 15
3.23 6906 15
3.34 7031 16
3.45 7125 17
3.56 7188 18
3.69 7281 18
3.80 7375 18
To yours:
0 4000 4
0.09 4063 2
0.2 4156 -1
0.31 4219 -3
0.42 4313 -4
0.51 4375 -3
0.62 4500 -2
0.73 4594 1
0.84 4656 1
0.95 4750 0
1.04 4875 0
1.15 4969 0
1.26 5031 0
1.37 5156 1
1.46 5219 1
1.57 5313 1
1.68 5406 1
1.79 5500 1
1.89 5594 0
2 5625 0
2.1 5750 0
2.21 5813 2
2.32 5906 2
2.43 6031 3
2.54 6063 3
2.65 6156 4
2.76 6250 4
2.87 6313 4
2.96 6438 7
3.07 6500 7
3.18 6563 7
3.29 6688 8
3.4 6750 8
3.51 6813 8
3.62 6906 9
3.71 6969 9
3.82 7031 10
3.93 7125 10
4.03 7188 10
4.14 7250 10
4.25 7313 10
4.34 7375 10
Your car also is an RS, you ran 2.15 sec 4k-6k not bad, but I'm no professional. Now I see it, his timing is slightly behind about 2*.
fid your timing is a little low, just add 1* at a time here and there, compare times and stop adding * when no more power or knock. May take about a dozen pulls and start at about 3200rpm to be easy on the eng
Old Jul 28, 2007 | 03:37 PM
fid's Avatar
fid
The car really only peaked 23psi very briefly and probably held closer to 19/20psi.
I think my nervous system is fried lol. After making more pulls with the car it does feel alot better with the stock airbox, damn ebay intake, but it is definately laying down after peak torque. That is where I am under timing the car is coming into play I bet. I have to start playing with the tune as it was just a rough in to begin with. Thanks for everyones help so far and keep anymore insite coming, I will keep updating this thread as I get the tune more dialed in .
Old Jul 28, 2007 | 07:06 PM
burgers22's Avatar
Have you done the air box mod? Cunning away the lid on the opposite side from the scoop will help reduce the presure drop on the stock setup and you shouldn't see a significant rise in IAT.
MB
Old Jul 28, 2007 | 07:22 PM
RazorLab's Avatar
3* at 6,000 rpm would make any evo slow.
Old Jul 28, 2007 | 08:46 PM
fid's Avatar
fid
MB
No I haven't but was considering it before I bought the intake. Really didn't want to hack the stock box up but not bad idea now.
Like I said before this is my first shot at the tune with the new setup and I was being overall conservative. My previous tune with just the TBE and EBC I was seeing 6-7* but wanted to dial in the A/F load sites first and didn't know how the motor would like that much timing with the 20G. Even with 3* at 6K with the stock airbox is 3 seconds faster to 7500 then it was with the ebay intake which seemed to by my problem.
Old Jul 28, 2007 | 08:47 PM
C6C6CH3vo's Avatar
since the load went from 220 to 260 at 6000rpm the timing dropped, good reason to keep adjacent cells close if your going to adjust the boost frequently. I dont know what IX's run at 6000 but I try to aim for 11* and I have seen 16*.
Just monitor knock as you add in timing
Old Jul 28, 2007 | 10:50 PM
ixbreaker's Avatar
+1...my evo ix rs runs 11* @ 6k and 16* @ redline...good observation^
