What do guys think of these logs!!!
Old Aug 11, 2007 | 02:06 PM
ant_turbo's Avatar
And this is on 91 octane @22psi and AF are in the mid 10's Done in 4th gear
My Mods.................................
HAFE MANI AND o2,GT30R_BB
255FP,780 INJECT
UICP/LICP,HKS FILTER
3'TURBOBACK CATDELETE
UPGRADE INTERCOOLER,,
MANUEL B/C..
Old Aug 11, 2007 | 03:50 PM
nj1266's Avatar
A few questions:
1. Why do you stop your log @ 6500 rpm? The log should be from 2500-7500 rpm. If you do not have room to go to 7500 rpm, then do a 3rd gear log.
2. Your car begins to knock @ 6500 rpm (7 and 8 KS in the first and second log). We do not know if this is real knock or lift off knock. That is why your logs should be longer than this.
3. How do you know that your AFR is in the mid 10s? There is are no wideband numbers in the log. Are you relying on the narrowband?
Old Aug 11, 2007 | 04:04 PM
ant_turbo's Avatar
Ya I did run out of room!! I have ZEITRONIX WIDEBAND,,,
I guess I'll make some more rums tonight,,,
Originally Posted by nj1266
A few questions:
Old Aug 11, 2007 | 06:40 PM
mrfred's Avatar
A few questions:
If the powerband peaks after 7000 rpm, then going to 7500 rpm makes sense. Otherwise, might as well stop at 7000 rpm.
Old Aug 11, 2007 | 06:42 PM
kreionic's Avatar
Since you have the ZEITRONIX why dont you log your a/f with evoscan?
Old Aug 11, 2007 | 06:51 PM
Ph3n1x's Avatar
Because the Zietronix can log other critical information like boost and EGT. Plus its easier to read and track.
Old Aug 11, 2007 | 08:08 PM
kreionic's Avatar
Fair enough
