GT35r Suggestions
Old Sep 18, 2007 | 09:35 AM
  #31
mfr122887's Avatar
Thanks for the responses, I really appreciate it. I think next up is a meth kit. Does 390 seem low for what I have?
Old Sep 18, 2007 | 09:45 AM
  #32
kinloch99's Avatar
it does seem low, do u have a intercooler? the stock with a 35r is way to restrictive. also i think a cam change would yield a nice power increase, u need more up top with that turbo.
Old Sep 18, 2007 | 09:50 AM
  #33
kinloch99's Avatar
r u also on the stock block? its a big turbo for a stock motor to push.if so i wouldnt push it to far, unless u plan on rebuilding the motor.
  #34
mfr122887's Avatar
Yes, I do have an intercooler, the previous owner told me it was a Peakboost kit. There are HKS 264's in there now, do you think this is holding it back up top? The previous owner made 440 on pump at 25lbs and 502 on C16 at 30lbs. I'm not really concerned about how high the number is but I'm just wondering if I am where I should be at the current boost level.
Old Sep 18, 2007 | 09:52 AM
  #35
mfr122887's Avatar
I am on the stock block so I am not trying to push it too far. I just want to make sure I'm not down on power.
Old Sep 18, 2007 | 09:56 AM
  #36
kinloch99's Avatar
i guess u r where u should be, why didnt u raise the boost for the tune?
Old Sep 18, 2007 | 09:57 AM
  #37
kinloch99's Avatar
ok just read it , u were leaking
Old Sep 18, 2007 | 09:58 AM
  #38
kinloch99's Avatar
well i think u get that problem fixed u will be their.
Old Sep 18, 2007 | 09:59 AM
  #39
mfr122887's Avatar
Sean Ivey and I agreed that 22 psi would be a safe 93 octane setting. I guess I could turned it up more but I didn't want to push it with only 93. With meth I'm thinking about 28 lbs.
Old Sep 18, 2007 | 10:01 AM
  #40
mfr122887's Avatar
I wasn't sure, the other day before the tune I pressure tested the car and it was making small bubbles out of the BOV vent. (The APS has an oval opening on the outside). When I tested later after I drove it it didn't do it. I'm gunna try it again to make sure.
Old Sep 18, 2007 | 10:03 AM
  #41
mfr122887's Avatar
And the BOV leaing I was talking about previously was due to the turbo surging in 5th gear.
Old Sep 18, 2007 | 10:11 AM
  #42
AlwaysinBoost's Avatar
I was getting surging @ low RPM with my 35r in 5th, 4th and sometimes even 3rd gear. I've been told that 280* cams are the cure for that but I sold them before I could test it out.
Old Sep 18, 2007 | 10:13 AM
  #43
mfr122887's Avatar
I didn't try it in 3rd or 4th yet. Thanks for the info.
  #44
High_PSI's Avatar
Go for 280's 100%. Buschur has some Custom cams that'll make your car sing. 264's are in fact too small a cam for a GT35R.
Old Sep 18, 2007 | 10:16 AM
  #45
mfr122887's Avatar
The more I read the more I realize that they are too small for my car. I just don't want to have to deal with having to install new ones and have it retuned. I'll prob stick with these for now until I get the bug for more power.
