GT35r Suggestions
Old Sep 18, 2007 | 03:10 PM
  #46
ThEHiTMaN's Avatar
Originally Posted by mfr122887
Yes, I do have an intercooler, the previous owner told me it was a Peakboost kit. There are HKS 264's in there now, do you think this is holding it back up top? The previous owner made 440 on pump at 25lbs and 502 on C16 at 30lbs. I'm not really concerned about how high the number is but I'm just wondering if I am where I should be at the current boost level.
Not bad.... My car only made 370WHP on pump and 453WHP on C16/93 (DJ numbers) with my previous tune. I am now working with Mellon to get these numbers up.
Old Sep 18, 2007 | 03:18 PM
  #47
mfr122887's Avatar
Originally Posted by ThEHiTMaN
Not bad.... My car only made 370WHP on pump and 453WHP on C16/93 (DJ numbers) with my previous tune. I now working with Mellon to get these numbers up.
My numbers were also on a DynoJet I believe.
Old Sep 18, 2007 | 04:30 PM
  #48
ThEHiTMaN's Avatar
what clutch do u have my runs were in 97 degree heat but my numbers were corrected for that I think dyno run says 1.03 std
Old Sep 18, 2007 | 04:32 PM
  #49
mfr122887's Avatar
Exedy Twin Disk
Old Sep 18, 2007 | 04:44 PM
  #50
ThEHiTMaN's Avatar
Exedy Twin Disk
stocker here... lol might be an issue but I do not feel it slipping.....
Old Sep 18, 2007 | 04:46 PM
  #51
mfr122887's Avatar
I'm confused? Are you saying that the clutch slipping might be the reason that I am down on power?
Old Sep 18, 2007 | 04:49 PM
  #52
ThEHiTMaN's Avatar
no sorry I am saying that might be why I am down on power lol your right where u should be.
Old Sep 18, 2007 | 04:50 PM
  #53
mfr122887's Avatar
oo ok
Old Sep 18, 2007 | 04:58 PM
  #54
ThEHiTMaN's Avatar
basically 400ish on pump and 500ish on c16 ur slightly lower at 390 but I was reffering to the previous owners numbers being where they should be. do u have a way of logging ur car I would be interested to see logs...
Old Sep 18, 2007 | 05:01 PM
  #55
mfr122887's Avatar
basically 400ish on pump and 500ish on c16 ur slightly lower but I was reffering to the previous owners numbers.
He dynoed 440 at 25lbs on pump, so I guess 390 is about right at 22lbs. Of course you have to take into consideration for the different dynos.
Old Sep 18, 2007 | 05:05 PM
  #56
ThEHiTMaN's Avatar
I am running about 23-24psi now I was tuned on 21-22 so our numbers are fairly close... I am working on getting those numbers up
Old Sep 18, 2007 | 05:06 PM
  #57
VenomEVO8's Avatar
dont forget temp... Its very hot in south florida
Old Sep 18, 2007 | 05:07 PM
  #58
ThEHiTMaN's Avatar
I would like to see some of ur logs if u have a way to get them.
Old Sep 18, 2007 | 05:09 PM
  #59
mfr122887's Avatar
I don't have any yet. I'm thinking of buying EvoScan instead of using Mitsulogger. ANy suggestions.
When I have some time I'll go get some logs. Any specific conditions you want?
Old Sep 18, 2007 | 05:10 PM
  #60
ThEHiTMaN's Avatar
sure is hot here and humid if I correct my numbers in dll I am over 400hp
