Copy 88840013 to 88840016 ???
Old Aug 24, 2007 | 06:40 AM
Dennis_I's Avatar
Hello!
Is it possible to copy my friends map whit internal ID 88840013 to my 88840016 ??? (but whit my own Imob code)
The VVT, Fuel map and timing seems to be the same values but his boost values will not work on my -16 ECU... And those are the ones i want
Is it only a software difference between -13 and -16???
Brgds
/Dennis
Old Aug 24, 2007 | 06:53 AM
tephra's Avatar
i guess the question is why?
presumably 16 is newer
Old Aug 24, 2007 | 09:41 AM
Dennis_I's Avatar
His boost caracter is what i want, because we already have same fuel map, ignition and VVT... But he is having a different ECU ID, so the numbers for the boost he is using making my car to only boost 0.7Bar about 10PSI...
Old Aug 25, 2007 | 07:09 AM
Dennis_I's Avatar
If i explain from the beginning, can i flash my friends -13 ECU evo IX euro and put my own imob code, and send to my -16 evo IX euro, will my become a -13???? Will it work???
brgds
Dennis, Sweden
Old Aug 27, 2007 | 01:05 AM
DimitrisIX's Avatar
does your friend have a different size restrictor at the wastegate?
Old Aug 27, 2007 | 03:16 AM
Dennis_I's Avatar
Yes, but i will have the same restrictor as he uses.... it`s a main fuel nozzle from a Keihin Carburator
Old Aug 27, 2007 | 03:22 AM
tkklemann's Avatar
Originally Posted by Dennis_I
Hello!
Brgds
/Dennis
No, I would not take this route.
Even so, if you could, chances are that you car will be boosting differently than his even with using his same numbers. We have found throughout everyone now setting up different boost values on their cars are producing different loads/boost profiles.
So, chances are very good that even if you set up your car exactly like his, your boost curve won't be the same, even more prevalent with different mods. You can transfer over his numbers, then go from there if it gets you closer to where you want to be. In the end, I think you will find that to get a boost curve on your car looking like his, your numbers will be different.
Old Aug 27, 2007 | 06:49 AM
Dennis_I's Avatar
Thing is that we did this on another Evo IX but it had -13 ROM since factory and it works super on that car... And now i bought a Evo IX but it has the -16 Rom....
Tomvas1992
Jun 22, 2016 09:44 AM
EVO VII georgia
28
Dec 6, 2009 05:13 AM
Danieln
Mar 9, 2009 02:48 PM
mscorei
Apr 6, 2008 07:50 AM
Fredd^
Sep 5, 2006 06:09 AM
