3rd gear log
Old Sep 24, 2007 | 08:44 AM
Jack_of_Trades's Avatar
Yeah, thats quite a bit of timing for a mail-in. I'd guess that you are running under 21psi at least???
Old Sep 24, 2007 | 09:25 AM
8UpUrV8's Avatar
I actually turned down the boost before I did the runs, and had planned to keep it there until I get a wideband. I've been running 1.55bar for some time now, but now it's around 1.45bar. I may turn the boost back up and do some more logs(good idea or leave it at 21psi?) but I just wanted to make sure the tune was ok.
As soon as I get a wideband I'm subscribing with Jestr to perfect this tune.
Thanks guys for all the replys.
EDIT: How do I check IDC?
Old Sep 24, 2007 | 11:08 AM
Just noticed you get a huge spike when you abruptly let off the gas at the end of each pull. I wonder if you are getting mechanical "phantom knock" from the engine moving around so abruptly when you take the load off of it? Loose or worn motor mounts perhaps or something making contact with the engine or transfer case like the downpipe? Just a thought.
spomi
Cobb AccessPORT
Oct 8, 2016 05:30 PM
villarrs
May 20, 2014 05:20 PM
maperformance
11
Sep 21, 2009 07:25 AM
mrfred
Jun 16, 2009 03:02 PM
