Will either of these 2 Serial to USB Adapters work?? Please enlighten!
Old Oct 8, 2007 | 12:02 AM
Inprogress's Avatar
I've found 2 on ebay...
http://cgi.ebay.com/USB-to-RS232-Ser...QQcmdZViewItem
http://cgi.ebay.com/USB-2-0-to-9pin-...QQcmdZViewItem
Are there any others that are suggested first? I've seen some as expensive as $30+, would like to think they're cheaper then that.
Thanks
Old Oct 8, 2007 | 01:40 AM
Inprogress's Avatar
No one??
Old Oct 8, 2007 | 02:14 AM
Roberto's Avatar
You've got to be kidding us! A $30 usb-serial adapter is too much for you? If that is true, you should not even be able to afford an Evo.
This is the ECUflash forum. ECUFlash runs off of a Tactix USB interface and does not even use a serial port. In fact, you do not even mention what you need to use the adapter for.
Perhaps you need it for a wideband O2 sensor system like an Innovative LC-1, but I'm just guessing. If that is the case, I recommend the Keyspan (part no. USA-19HS), which will work flawlessly with Evoscan, the Tactrix interface, and an Innovative LC-1 wideband. But I'm just guessing because you never even mentioned what you need the adapter for.
BTW, both of those adapters are craptastic, and I would not waste my time with them. If your time is worth anything at all, I would not waste an hour or two of it messing with that junk. Unless you work at McDonalds, you'll easily pee away more than $60 of your time that way.
Old Oct 8, 2007 | 04:51 AM
Inprogress's Avatar
It's for a LC-1 wideband. Ill look into the keyspan one, any others?
Thanks
Old Oct 8, 2007 | 08:05 AM
Mr. Evo IX's Avatar
I use the bestbuy one, although it is probably the most expensive it was in stock and it worked with my AEM wideband.
Old Oct 8, 2007 | 12:55 PM
XetronicEvoVIII's Avatar
get the keyspan, highly recommened for tooning/logging.
Old Oct 8, 2007 | 02:02 PM
kreionic's Avatar
I use the belkin with my LC1. Innovate says as long as it has a driver with it it should work. They said get anyone except the radio shack one. But people have been getting that one to work aswell
Old Oct 8, 2007 | 03:16 PM
Inprogress's Avatar
Like the Belkin F5U109???
evovin
38
Dec 20, 2017 08:39 AM
Mystic_Korean
Lancer-Mirage Compatibility Forum
15
Nov 16, 2007 10:19 AM
Walkingchaos
Lancer Aftermarket Forced Induction Tech
Oct 14, 2006 05:24 AM
gatorade
13
Jul 25, 2006 06:58 AM
