e7 rom definition file needed for 98640016
Old Oct 17, 2007 | 12:43 AM
MR's Avatar
MR
Anybody got the definition file for this e7 rom id 98640016?
Please assist!
File Type: zip
Old Oct 17, 2007 | 02:25 PM
burgers22's Avatar
Hi
What I have done is change the internal ID to 98640014 in a sort of reverse of a map scramble, this will alow you to use the reasonably complete xml for the 98640014 ROM also from a JDM VII, I've checked a few of the major maps and they seem OK.
You should just be able to open it up if you have the above xml. Post back if you need any more help.
MB
File Type: zip
Old Oct 18, 2007 | 04:02 AM
MR's Avatar
MR
Hi bro,
Appreciate the help...
I need your help in the boost limit area...the rpm towards the higher rev is jumbled. Thanks for the help if u can look into it again...i want to remove the boost cut.
rpm
2000
2500
3000
3500
4000
4500
5000
255996
135484
Originally Posted by burgers22
Hi
MB
Old Oct 18, 2007 | 11:46 AM
burgers22's Avatar
Hi
You really should be Ok to change the boost cut value in the right hand column, the left hand column is jumbled, as is the left hand one for the BDEL and WGDC, however the change only needs to be done in the right column so I'd go ahead and change the boost cut. I'll have a go at getting the other columns sorted when I can, but moving house right now so not much time.
I must have been having a bit of a brain fart last night, here's an xml, it's just a copy of the 98640014 renamed and with the ecuid changed so ECUflash can pick it up, a bit more sensible than how I did it last night.
MB
Edit, better xml with the RPM corrected and MUT table locations corrected, working on the values for 2 byte load.
File Type: zip
TariqEvo
Dec 9, 2021 12:36 AM
IH8TOADS
Jul 4, 2017 05:02 AM
YaroRS
Apr 21, 2012 01:08 AM
lukasz4turbo
14
Nov 17, 2010 02:14 PM
