soft boost-cut
Old Oct 23, 2007 | 05:38 PM
voidhawk's Avatar
I've noticed a new parameter in EcuFlash v.1.33 that's "Min Temp for Full Boost Control". Does anybody know where this temperature is measured? It is set to 85C in my ROM. I'm wondering if I'm not getting "full boost control" when the car is cold because this parameter might be set too high?
Old Oct 23, 2007 | 09:27 PM
codgi's Avatar
Originally Posted by voidhawk
I did talk to Pete about it, and he tried to adjust the tune to account for it. However, like I said - it only happens under very specific circumstances which are difficult to achieve repeatedly, and that makes it hard to tune for. So I just adjusted my driving to work around it. Flogging the car without it being fully warmed up is bad anyway.
In the end no tuner will (or can) take the same amount of time to tweak the tune for every possible scenario as I can when doing it myself. They'd go out of business spending this much time on a single car, and I'd also be unwilling to part with my car for that long. That's why DIY/ECUFlash is such a great thing - I can tune/tweak as I go, making small incremental changes over months if need be until everything is perfect. I do very much appreciate all the work & enthusiasm the various people in the Evo "self-tuning-community" have poured into this - it's a great and wonderful thing!
Next step for me is to do the JDM MAP sensor mod so I can accurately log boost, and ...
while (tune < perfect)
... read
... learn
... tweak
... log
end
I'm sure I'll get it right eventually - after all, this stuff isn't rocket science
you never get tired of that joke do you . Be careful with the labels of some values in ECUFlash they aren't always right.
Old Oct 24, 2007 | 12:46 PM
RazorLab's Avatar
It is coolant temp. You shouldn't be flogging the car until it's up to temp anyway.
Old Oct 24, 2007 | 01:02 PM
Evo_Jay's Avatar
and 85c is the stock setting
Old Oct 24, 2007 | 01:24 PM
voidhawk's Avatar
thanks guys - does anybody know what the "middle of the gauge" for the stock water temp gauge corresponds to in actual temperature? I have an oil temp gauge, but not water temp (other than the stock one). I always wait until the stock water temp is in the middle before getting on it, but I've noticed that my boost problems will persist until after the oil temp also rises above ~120F (50C). After that everything works as it should.
Old Oct 24, 2007 | 01:26 PM
RazorLab's Avatar
Log your coolant temp via evoscan or mitsulogger and find out what position on your car means what.
The factory sensor is so slow I would imagine there is alot of variation between cars.
Old Oct 24, 2007 | 09:08 PM
mrfred's Avatar
... read
... learn
... tweak
... log
end
I like that. You should put that in your sig.
Old Oct 24, 2007 | 09:15 PM
tephra's Avatar
I would swap log and tweak thou
Old Oct 25, 2007 | 04:07 PM
urBan_dK's Avatar
Voidhawk, how far we've come since you helped me install that Defi Boost Gauge ages ago...
Anyway, I'm in the same boat you are. I have a WORKS tune with a pretty bad boost spike. My JDM MAP sensor arrived yesterday and I'm going to try and cure this problem for good this weekend.
I'll let you know what I find out...
Old Oct 26, 2007 | 12:52 AM
codgi's Avatar
^^ where you been hiding kid?
Old Oct 26, 2007 | 06:04 AM
voidhawk's Avatar
hey, good to hear from you . Let us know how things work out ...
Old Oct 26, 2007 | 12:36 PM
urBan_dK's Avatar
<OT>
Codgi and Void, we need to hang out again some time. Let me know if you plan on doing anything again, I'll join ya'll.
</OT>
