Cams to big for Stock ECU?
Old Nov 4, 2007 | 08:25 AM
denolloyd's Avatar
Originally Posted by gunzo
Its called time and effort versus returns ..
You need to be conversant with the stock ECU .. and you need to spend time to fix the idle ..
Both of which NO TUNER is willing to dwell on .. with the amount of time spent and the money paid .. If I'm a tuner I rather you buy something else like AEM / Vpro / Autronics ..
Noticed I don't even bother posting what I know .. knowing that 'TUNERS' use this place as an information bank to find suckers who willingly pay to have their cars experiment on ..
Not always the case. Jestr has spent countless hours tuning my car to improve drivability. He takes his time and gets it right. The only tuner I have ever dealt with, and its always been a great experience.
Old Nov 4, 2007 | 08:27 AM
EvoDan2004's Avatar
Originally Posted by denolloyd
I have BF 272's on a flash along with the mods in my sig. No stalling issues. Idle is rather lopey though. I love it!
you might want to update ur sig man.
Old Nov 4, 2007 | 08:28 AM
denolloyd's Avatar
Yeah, i know. Cars in the shop again and Im tired of up dating it. Going back to a 2.0.
Old Nov 4, 2007 | 10:14 AM
Jack_of_Trades's Avatar
Its not just the super aggressive cams, like the revolvers, that will create difficultly at idle with the stock ECU. It also depends on the other mods you have to go along with the cams. Obviously the injector size can play a role and MAF/MAFT mods create more tuning hurdles. No two cars are exactly the same but from what I have seen, I feel 95%+ of cammed/modified cars can have a very decent idle with the stock ECU. The more we learn how to mod the stock ECU (it has come leaps and bounds in only a few months too) the better this problem can be solved.
Old Nov 4, 2007 | 10:25 AM
denolloyd's Avatar
Well said! When I first upgraded my car, I installed HKS 280 cams. Idled well even without a tune. The next day I installed 880 Injectors... They killed my idle... Of course Jestr fixed all that...
Old Nov 6, 2007 | 05:15 AM
tkklemann's Avatar
I just finished tuning a stock ECU 03 with 280 cams and a few other mods.. It's not difficult at all, and can be done.
Anyone saying it cannot be done simply doesn't know what they are talking about.
Old Nov 6, 2007 | 09:30 AM
Erik@MIL.SPEC's Avatar
I don't think 280's are the kind of cams we're talking about, unless they have really high lift.
Revolvers seem to be the ones I've seen the most issues with. I have seen Cosworth M2's tuned with no problems on 8's.
Old Nov 6, 2007 | 10:47 AM
TTP Engineering's Avatar
We have never had a problem tuning ANY cam on OEM ecu via reflashing.
Old Nov 6, 2007 | 04:17 PM
MalibuJack's Avatar
The trick to getting a cammed car to idle well is keeping stable airflow through the MAF sensor. ECU tuning for idle is primarily about raising idle speed and generating vacuum by altering idle timing and ISCV adjustments. Other factors are adjusting the DV if possible so that varying loads don't draw the valve open affecting airflow which will cause stalling.
Old Nov 7, 2007 | 04:38 AM
MalibuJack's Avatar
There are devices that make this alot easier.. My blowthrough meter's electronics have a threshold where it goes no lower than a certain point, which results in a very stable idle MAF signal and the car runs rock solid. The ECU+ has this feature built-in also, where you can set a solid idle signal. But you can work with any piggyback device to make adjustments also.
You can do this directly in the ECU, but its a bit more involved, and usually isnt necessary if you can get the idle speed up.
Cams and large injectors need a higher idle than stock, 1000-1200rpm is a normal idle for cammed cars.
Both cams and large injectors complicate things because of the extremely low duty cycles and closed loop trims that also shift depending on the parasitic load on the engine (A/C, PS pump, Alternator) so if you want to make these adjustments properly, make them while the a/c is on high and headlights are on, this will place the most load on the engine at idle.. once you have that, you can finalize the adjustments with everything off.
Old Nov 7, 2007 | 09:14 PM
raiceboi697's Avatar
what would be the proper idol vacume for cosworth M2 cams? im at about 11 on my defi gauge....im almost thinking lower will make it idol a tad better..ive been at this idol for a week now and its idolin a lot better....
chaotichoax
Apr 12, 2020 11:55 PM
Ped
Feb 19, 2016 02:47 PM
evolved8 bs
Nov 29, 2015 09:55 PM
AdamWest
Nov 2, 2010 08:59 AM
EvOcHaRgeR
15
Nov 6, 2006 10:23 PM
