Car won't idle Evo9 Cosworth Cams
Ecuflash noob...need help
My car won't idle correctly with the AC on or off, it constantly goes up and down. I know i want to be using the 88590015 but i can't get it converted. i have attached a screen shot showing my current idle settings. i have searched and found the data needed regarding the cossie cams.... just can't convert to 015 file and get the scaling correct. any help would be great. my tuner is busy and can't get to it for a few days....
Ecuflash V1.33
Internal ID 88590013
Ecuflash V1.33
Use a older version of ecuflash, like 1.29 and they should show up correctly.
However 9's should idle just fine with cosworth cams without any rom mods. You sure something isn't wrong with the install?
All the cosworth 9 cams installed at the shop purr like kittens.
buschur installed my cams... so it was done correctly
can someone post the stock idle settings
thanks
I keep trying the new versions that come out, and immediately go back to 1.29. And like Bryan said, my 9 with cosi's had no idle tweaks at all and purrs. Make sure you dont have advance between 0-30 load up to 1500 rpm in your mivec table. Adding timing in mivec will give you a lopey idle. Im running 5 degrees timing in my normal maps in the idle range.
Thanks
I made a link to version 1.30 (newest one before it got weird) in this thread
https://www.evolutionm.net/forums/sh...d.php?t=305301
You can find all the versions you want here
http://www.openecu.org/index.php?tit...rev&oldid=1979
Just click on the older version arrow and you will get to 1.29a
ok changed that in VVT Map 1 main. the other timing maps High octane 1-3 and Low octane 1-3 have 5 degrees up to 1000rpm, 10 degrees at 1250rpm, 15 degrees at 1500rpm. so do i need to make them all 5 degrees in the idle range on all of those maps between 0-30 load or 0-40?
Thanks
Thanks
