Zeitronix AFR in DataLogLab
Old Nov 11, 2007 | 11:23 PM
RazorLab's Avatar
Hey all,
I can't for the life of me get my ZT-2 AFR, logged in evoscan, to show up in DataLogLab.
I've been using the ZT-2 logger for AFR up till now and decided I would just like it all contained in my Evoscan logs.
The ZT-2 AFR shows up fine in my evoscan logs but won't load in Dataloglab with the current def. I have the ColumnTitle name matching, etc
I have a feeling it's because ZT-2 logs as 12.9 instead of 12.9827 like other AFR monitors do.
Anyone have a DLL def working with ZT-2 within evoscan logs they can post?
Thanks in advance.
Old Nov 12, 2007 | 01:21 PM
turbotiger's Avatar
I believe it's due to the fact that there's more than one column labeled AFR. You can either delete the incorrect column before loading it up in DLL, or rename the column, and edit the DLL data definition.
It's just easier if you delete the incorrect AFR column, or don't log the ecu AFR values.
Old Nov 12, 2007 | 02:00 PM
dudical26's Avatar
I have a DLL definition I can send you that will work with EvoScan logs for ZT2 AFR.
Send me a pm with your email and I'll send you the file.
Old Nov 12, 2007 | 02:45 PM
RazorLab's Avatar
I have the column labeled WideBandAFR.
Thanks! PM sent.
Old Nov 13, 2007 | 11:13 AM
turbotiger's Avatar
You can email me your current dll definition and log file and I can write one for you.
Old Nov 13, 2007 | 01:25 PM
dudical26's Avatar
problem solved. I sent him my def file.
Ghost1t
Feb 7, 2011 12:51 AM
monkeyevo
Jan 16, 2011 10:44 PM
4g63_guy
Jun 11, 2009 07:33 PM
SOEX
Oct 10, 2008 12:28 PM
nonschlont
Sep 30, 2008 10:26 PM
