An Idea on logging backpressure need some info and input.
Old Nov 14, 2007 | 03:32 AM
dan l's Avatar
Don't evo's have an EGR temp sensor? If so you don't need that sensor for normal operation. Disable it in the ROM and use that as an input for things such as this.
Old Nov 14, 2007 | 07:15 AM
94AWDcoupe's Avatar
Heat is the enemy. Mounting from collector would be really hard to control the heat. You can take the signal from intake manifold side. There is an EGR port that goes through the head to the intake side. You can tap the intake manifold to feed off that EGR port. You will still need to use about 3 feet of coiled copper line to help cool the gas. There isnt going to be any pressure difference taking the signal this way. Not significant anyway. You should also have a buffer inline to help control the pulsed nature of the signal. I would try a plug with about .080 hole.
Old Nov 14, 2007 | 07:20 AM
94AWDcoupe's Avatar
Originally Posted by mchuang
Found a pretty interesting sensor, heard of it before never thought about it until now
At the bottom but I am sure any pressure sensor could work
http://www.kavlico.com/pages/industr...lications2.htm
This sensor will not be helpful. This is for measuring exhaust pipe pressure. The temps going through exhaust are 1/6th what they are pre turbine. The pressures are much lower as well.
Old Nov 14, 2007 | 08:41 PM
JKav's Avatar
you wouldnt happen to have a picture or part#
The internet is your friend.
http://www.powerstrokediesel.com/doc.../PSDmanual.pdf
2008 EBP sensor: 8C3Z-9J460-A
2005-2007 EBP sensor: 5C3Z-9J460-B
(EBP = Exhaust Back Pressure)
Boostfiend
18
Nov 1, 2010 10:13 PM
evostang
14
Oct 15, 2010 05:29 PM
Racecarzz08
Lancer Engine Tech
11
Feb 1, 2009 05:07 PM
diablo2184
Oct 15, 2008 07:41 PM
Ree
19
Feb 13, 2004 09:05 PM
