Thoughts on the wideband
Old Nov 14, 2007 | 07:15 PM
RoadSpike's Avatar
Ok so my wideband, a ZT-2 unit, is being erratic in its readings. Often it will just stay at 14.7 AFR and never change for great periods of time but then suddenly after a long drive it will periodically start working.
I've changed the sensor once about a week ago and it worked great for like 2 days then it started doing this crap again. The sensor is installed by the cat in the 3 o'clock position.
Any tips thoughts?
Old Nov 14, 2007 | 07:21 PM
electricevo's Avatar
Have you performed a free air calibration on it? Or does this type not need/have the provisions of a recalibration?
Old Nov 14, 2007 | 07:28 PM
RoadSpike's Avatar
no such calibration exists far as i can tell
Old Nov 14, 2007 | 08:16 PM
merkzu's Avatar
I'd email zeitronix. They have gotten back to me quickly before. Wonder if the display shows 1 lambda when there is no signal, could be a wiring problem?
Old Nov 15, 2007 | 06:58 AM
Zeitronix's Avatar
A bad O2 sensor or missing connection between the Zt-2 and the O2 sensor. If possible swap for a good known O2 sensor. Check wiring. Make sure there are no intermittent connections between the O2 and the Zt-2.
email sales at zeitronix dot com for details. We will walk you through it step by step.
Old Nov 15, 2007 | 10:59 AM
Evo_Jay's Avatar
Also check the phone jack connector. Once I damaged this piece and mine gave eradicate readings.
Old Nov 15, 2007 | 11:33 AM
Zeitronix's Avatar
Yes, in electronics is all about connections. Electromechanical parts are the most vulnerable
Old Nov 15, 2007 | 11:49 AM
mifesto's Avatar
my friend had this issue also.... but his was loose wiring. i know running leaded gas will lead to wideband readings 'sticking' but doesnt sound like the case according to your description.
kyoo
Jun 30, 2019 12:44 AM
Femi
AEM EMS
23
Apr 5, 2016 11:38 AM
trinibt65
Aug 31, 2015 12:52 PM
dutch555
16
Jun 4, 2012 12:34 PM
Jim in Tucson
18
Sep 17, 2007 05:59 AM
