Let's see your fully tuned timing maps
Old Jan 1, 2013, 09:36 AM
  #1996
todd6027's Avatar
Originally Posted by Biggy VIII
WHP man, WHP.
325 whp on mustang, 365 whp on dynojet.
Anyway I am out of this discussion, as I don't wanna feed the troll.
Cheers.
Old Jan 1, 2013, 01:40 PM
  #1997
domyz's Avatar
Let's post some timing maps guys. Here is my current one to revive the thread
There is A LOT of work in this map, as I got the car in July 2010. I spent about 2000hours on these forums ... I decided to transfer my tuning knowledge from my celica and learn more about evos.
My car seem satisfied with this current one :
-Street tune, 91 octane, IX turbo, bolt-ons, stock cams.
-AFR: 12.5@Spoolup and steady 11.5, then leaning it a little bit up to redline.
-23psi taper to 21psi, ~265 load taper to ~245.
-7500 redline.
Still some minor things to adjust, but I'm waiting for summer up here in Canada
Old Jan 1, 2013, 02:17 PM
  #1998
prowakeskater's Avatar
thats a good looking map
Old Jan 1, 2013, 02:58 PM
  #1999
Biggy VIII's Avatar
-7500 redline.
Looks smooth and fine.
Old Jan 1, 2013, 05:36 PM
  #2000
3K
3K's Avatar
Originally Posted by dom11
Ok let's say 95% duty is no more than 370-380 BHP on dyno dinamics.
Actually 97-98% is 380BHP for sure.
WHP man, WHP.
Cheers.
This is correct. I made 362 WHP at 95-99% idc on stock inj.
-7500 redline.
Nice map. Any numbers with that set up?
Anyone have maps for larger turbos?
Old Jan 1, 2013, 05:47 PM
  #2001
domyz's Avatar
No I haven't any updated Vdyno numbers. Around 320 maybe. Stock cams are holding the car like a parachute
Old Jan 1, 2013, 05:50 PM
  #2002
Biggy VIII's Avatar
for all-around 2.0 stock turbo kelford tx264 is my choice.
Old Jan 1, 2013, 08:03 PM
  #2003
domyz's Avatar
Thanks for the advice mate, but since a long time I'm leaning toward GSC S1. According to the specs thread, they are a bit more agressive than kelford 264 ... Turbo won't stay stock, I bought a IX turbo to get a core for a stock frame upgrade.
Old Jan 2, 2013, 01:19 AM
  #2004
3K
3K's Avatar
Nice, for sure cams will open the top up. Excellent choice on the gsc s1. Personally though I'd go with s2's, especially if you plan on upgrading the turbo.
Old Jan 2, 2013, 02:07 AM
  #2005
el.guerrero's Avatar
double post!
Old Jan 2, 2013, 02:10 AM
  #2006
-7500 redline.
That's fine very good job.
Btw i think that on 91 octane we can run with stock ignition sistem about 10/11/12 degree up top.
On 93 i'm looking for a solid 14* . Hoping is possible.
My timing map which i'm working on, is about the same , minor differences but that's all.
Mods are nearly identical.
I wanna try to peak @25psi and tape to 20/21psi, spoolin up with target of 12.5 afr and then tape to 11.5 to 6500 and 11.3 to 7500.
Afr tune is 99% done. Timing needs a lot more skills
Old Jan 2, 2013, 03:05 AM
  #2007
Biggy VIII's Avatar
If the turbo won stay stock, I would also run s1 or tx272. S2 or tx288 for turbos like Red and larger..
Old Jan 2, 2013, 04:18 AM
  #2008
Also gsc2 can be a good choose , looking forward is better
Old Jan 2, 2013, 07:11 AM
  #2009
vmrevo9's Avatar
well i've been self tuning my car for a while and this is the map i have now. its still a work in progress, i was actually working on a smoother transition for the lower load cells which i havent tried yet due to a short notice deployment. but i should be returning soon and i can continue to log and tune.
i also attached a log file from this rom. my car has always been knock prone but it has become a lot better.
i'm thinking timing is low but i can be wrong i always wonder when i see guys with higher timing in the higher rpm ranges.
i am adding some saikou-michi can catchs with the bigger 5/8" vent hole on the valve cover once i return so hopefully that will help some how.
from 5000 rpm and up is when i was seeing some knock recently so i plan on attacking this and the mivec map.
let me know what you guys think. Boost is 27peak tapering to 23. 93oct
this is my most recent dyno sheet, you can see where it starting knocking at about 5K and up.
Old Jan 2, 2013, 08:38 AM
  #2010
Biggy VIII's Avatar
It seems to me that you are running a little bit too much boost. Thats why you are knocking and cant run higher timing. 25psi tapering to 21 should be enough to get the same or a bit higher dyno numbers, on higher timing without knock. BBK-Full can manage some solid boost numbers, which are useless on 93 octane. Pushing the limits of the turbo is good on meth or E85.
I have posted my map for BBK-full https://www.evolutionm.net/forums/10...-post1975.html
I have pushed that turbo up to 390whp with some 50\50meth on mustang dyno.
Quick Reply: Let's see your fully tuned timing maps
