Evo 2byte Airflow changes
Old Dec 2, 2007 | 05:37 PM
RazorLab's Avatar
I'm now starting to do the 2byte airflow mod on all the Evo 9's that are tuned on our dyno. Figured it would be a nice data point for all the different levels of modifications.
Old Dec 2, 2007 | 06:02 PM
Jorge T's Avatar
Great data! Are you doing a scatter diagram graph in excel?
Old Dec 2, 2007 | 06:12 PM
RazorLab's Avatar
Old Dec 18, 2007 | 12:49 PM
RazorLab's Avatar
Here is a Evo 9 with a FPgreen and cosworth cams, on 91 octane.
Interesting thing here is that at peak airflow the car is running 20.5 psi, showing the FPgreen sure flows a bunch more than the stock turbo, even at 20.5 psi
Old Dec 18, 2007 | 01:32 PM
RazorLab's Avatar
Old Dec 18, 2007 | 02:06 PM
EvoBroMA's Avatar
thanks for the data! looks great.
how much boost are you tuning for in post #3. do you log boost?
also you can clearly see how much more flow at the lower rpms that stock gives you.
Old Dec 18, 2007 | 02:08 PM
RazorLab's Avatar
I usually target about 18psi or so up top on the stock Evo 9's as they get a bit grumpy on anything more on 91 octane.
I do log boost, but on the dyno.
Old Dec 18, 2007 | 06:32 PM
RazorLab's Avatar
Turns out I was plotting the RPM wrong between all the charts. I deleted the wrong charts and updated the first post...
Old Dec 18, 2007 | 06:52 PM
tephra's Avatar
cool - nice visual representation.
so the stock vs 9 - is that just a 9 tuned?
Old Dec 18, 2007 | 07:02 PM
RazorLab's Avatar
Evo 9
100% stock
All 3 plots are from the same Evo 9 on the same day
Old Dec 18, 2007 | 07:39 PM
EvoBroMA's Avatar
this is great stuff. wish more tuners would do this, and share data.
Old Dec 18, 2007 | 07:51 PM
kreionic's Avatar
hmm this is pretty interesting. I am seeing lower 2 byte airflow. I maybe have the wrong numbers in my .hex. What did you change the low and high bit in the map to?
Old Dec 18, 2007 | 07:57 PM
RazorLab's Avatar
What mods and what boost control if any?
Old Dec 18, 2007 | 09:04 PM
RazorLab's Avatar
Some Airflow and Load:
Old Dec 18, 2007 | 09:27 PM
tephra's Avatar
on the Load_Evo9 - TBE - Stock Turbo how much boost you running?
