Evo 2byte Airflow changes
Maf must be changing HZ up top as it doesn't make sense to me that the car needs more fuel up top but the airflow is the same. However we must remember this is read at the MAF so there might be a huge fudge factor here.
All the charts in this thread from me are on a Mustang Dyno, 3rd gear.
Greatly appriciate it man. Last question for you. How are you going into excel and setting a secondary Y axis? Mine is greyed out and cant seem to find away to put something in the secondary one. Sorry for going OT a little bit. we can take this to PMs if you like to
Once you start changing stuff near the MAF (like the filter), the MAF's calibration curve goes wacky and you can't trust that it's producing an accurate Hz number. I'd take those airflow (Hz) numbers with a grain of salt in that case.
Cool stuff though.
Cool stuff though.
Don't always trust the data. The numbers usually don't lie though.
Interesting isn't it?
Good stuff.
I should have been more clear. I was looking at the last two runs, both with cams. Still, looking back at the IDC lines for the two you've posted you can see that where it used more fuel it made more power. (No duh, right?
silvertune
Feb 1, 2016 03:30 PM
