remove maf honeycomb (not a noob lol)
Old Jan 8, 2008, 04:45 PM
E VOL IX's Avatar
no sir.. if the screen was out... your car was running differently... it spins the air a certain way and uses that to determine how much fuel to add...
The MAF sensor like on a subaru.. that has two screws is a denso style MAF they dont need a screen... but when it is built in to a tube like ours it uses the honeycomb to measure air flow... if the screen isnt in place it looks like you are into the throttle and tries to compensate by adding fuel.. so cruising and stuff it should run fine but it will run rich as hell when idling
Old Jan 9, 2008, 12:29 PM
AlwaysinBoost's Avatar
^^^ it doesn't "spin" the air at all, it just straightens it out. As long as your air filter doesn't mess with the incoming air you are fine.
Like I said above in my post, I've had NO SCREEN in my MAF for over a year and have no driveability issues at all. not at idle, not while crusing and deff. not @ WOT.
Old Jan 10, 2008, 06:42 PM
bnice01's Avatar
I take back what I said, all of sudden the next day my idle is stumbling. and afr's are 13-15. its probably the maf. my LTFT low is -11 LTFT mid -13 STFT idle is +3/-3. tried scaling the maf didnt really do too much, even tried to rescale my stock injector LOL still nothing. scaling both the injectors/maf just made STFT a constant negative or postive, long term didnt even change. Looking to swap maf's with a local, will post results.
Old Jan 11, 2008, 06:20 PM
bnice01's Avatar
update car is back to normal, buddy of mine had a maf laying around in his garage that he just gave me. thanks jhanksevo
Old Jan 24, 2008, 07:20 AM
Dorikun's Avatar
So.... What The Heck Stainless Steal Maf Honey Comb Is That?!
Old Mar 9, 2008, 09:30 AM
Ph3n1x's Avatar
IT kind of sucks when theres soo much pressure that the IAT sensor with the metal prongs get bent towards the turbo...lol
talonkev
Oct 22, 2016 11:23 AM
mikesevo8
Jan 31, 2016 02:02 PM
Hi Im Vinh
Sep 25, 2015 11:01 AM
NIevo
Sep 10, 2007 10:06 PM
nubby
10
Sep 11, 2003 06:02 PM
Quick Reply: remove maf honeycomb (not a noob lol)
