Meth Failsafe and Patches
Originally Posted by Jack_of_Trades;
Just tried it again, wires 'seem' to be in just fine. Still reading '0' for both MUT locations.
Which are the unused pins you are hoping the ADC0F is mapped to?
http://www.roadraceengineering.com/e...-ecuwiring.htm
PIN #52 shows +5V, and either PIN 31 or 32 was actually empty (diagram says it should have a wire for A/C). MrFred, what pin location was the ADC0F input when you tested?
I noticed the previous owner had a S-AFC installed at one time and cut the Mass Airflow wire so I think I might pull that pin out and use it to test all of the empty locations to ENSURE I am getting a good contact. I wish it wasn't 30F degrees out and wet right now, its gonna make it a fun time.
All of the unused pin locations on this chart:
I just had one thought. Have you tried driving the car while logging ADC 0F? This would be another way to be sure that its not connected to something already.
If it turns out that ADC 0F is not mapped to any unused pins on the Evo 8, another option is to highjack the rear O2 ADC input. It would be extremely easy to create a software rear O2 simulator to prevent the rear O2 CEL, and then that ADC input could be used for whatever.
Letting the car warm up right now. Once I confirm that the pin connections are 100% good, then I know for sure that the ADC0F isn't using any of those pins. The 8's have 2 wires we can use, the ICS auto mode input and the ICS output so there just may be 2 configurations, one for the 8's and one for the 9's.
So what exactly will be needed...will you hard wire or will you be using a harness or something? If we use the auto ics pin that means we can still use the button and switch on the fly?
It all depends how Tephra can set it up. I prefer going the 0V/5V triggering concept much better. If thats the case, it'd be best to have that wire hardwired at the ecu harness. Lets just hope we can find a way to use an open port on the VIII ecu.
I do to...just would be nice to have the option to switch maps still using the same button.
PIN 42! Thank god,lol. It registered on FFFF0x8929 only. Whew, that sucked. I literally had to un-install and reinstall the Mass Air-flow pin into each empty location. Those things are a pain to take out,lol.
I got a reading of 86 out of 255 when i gave it 1.70 volts. Sound about the same as you got Mrfred?
PIN 42! Thank god,lol. registered on FFFF0x8929 only. Whew, that sucked. I literally had to un-install and reinstall the Mass Air-flow pin into each empty location. Those things are a pain to take out,lol.
EVO8
May be it is easier to tackle the devil you know rather hunting for a spare pin.
I am sure one of the IC sprayer input (blue arrows) pin can be made redundant. and re-assign ADC0F to that pin? At present, I think those pins are digital inputs.
Thanks, god knows it sucked,lol. I was like a contortionist in my car trying to stay dry from the cold rain. The female pin (i.e; socket connector) is for 1mm pins. I'm not sure what size pins I ordered were so I'll let you guys know if they are for the larger 2mm pins or for the 1mm pins once they come in.
Its good that someone does the dirty work. :-) In the end, it brings in more people who are also willing to go the extra effort. In less than a year's time, we are going to have a very excellent suite of ECU tricks.
