Meth Failsafe and Patches
Hi All,
Rather than filling up my V4 thread with the failsafe stuff we decided to move all that discussion into here. So what we are doing is working out how we can get an external meth failsafe system to trigger the ECU to run failsafe maps... Take it away Jamie :) Cheers Dave |
MAP SWITCHING
Ok, first thing we are determining is how Tephra has used the ICS auto mode switch to switch to alternate FUEL/IGN maps. This is the biggest failsafe you can ever have. BOOST LEVEL SWITCHING The next thing is boost level. Most guys use a MBC so even if their alky kits failed and the alternate maps were used, you'd still be pushing some serious levels of boost. Using a MBC, in conjunction with the stock wastegate solenoid (boost solenoid), there might be a way to have the ECU switch on/off the boost solenoid so its CLOSED when the alky kit is fine, and its ON when the failsafe kicks in (I'm now thinking that if it just runs the stock boost map at around 17-19psi, that'd be good). If someone took the time to alter the boost map to run a different boost pressure, that'd work too. I'm assuming most people would want their alternate map to be tuned for the most boost/power they can get without their akly kit activated. That way if the alky system is busted or they can't afford more alky to refill the reservoir for a while, their car isn't a complete DOG on the highway. |
The MAP switching is done using the ICS switch. This is what the wires at the ICS switch do:
Green/White - (+)12v for light INSIDE the actual ICS switch (activated when parking lights/headlights are turned on) Black/Yellow - (-) Ground for light in switch Blue - Manual trigger wire for ICS relay (connect this wire to (-) ground to activate ICS relay) only requires 3mA of current *NOTE* The IC sprayer pump will stay on whenever this wire is connected to ground, its intended for momentary activations. Keeping this wire constantly activated for over 30 seconds could kill the sprayer motor. Blue/White - Auto ICS wire (momentarily give this wire (-) ground once to turn on AUTO mode, must release and connect to (-) ground again to turn off AUTO mode) only requires 3mA of current Black - (-) ground source for the MANUAL and AUTO triggers Ideally, you'd want the AUTO ICS trigger switched from momentary ground switching to: ON = connected to (-) ground OFF = no connection to (-) ground Doing so would simplify the use of most alky kits failsafe outputs to trigger the ALTERNATE FUEL/IGN maps. |
David, can the map switching be triggered under any conditions instantly? I'd assume you mimic'd the way the stock fuel maps switch between high and low octane maps, I could be wrong though.
I'm about to purchase a meth kit and this is something i'm very interested in.
Will these patches work anyway with people without an ICS switch like the 05+ Evo's
Originally Posted by daisaw1219
(Post 5080145)
If you've ever DL'd one of his patches and didn't donate any money to him, now would be a great time to show your appreciation and throw him whatever you can (even 5 bucks would help I bet). If you are kind enough to help Tephra out, go to www.Paypal.com and send any donations to his paypal account by typing in his email address which is "donations@globalshare.net". |
holy crap...i hope it wasn't his fault lookin at the laptop..."dontations coming +1"
Dude, that totally blows.
yup it sux :( right around christmas too :(
but please don't feel like you need to donate :) anyways back OT, i'm not sure if using the ICS is the way to go... maybe if we can find a universally free ecu input we could tap that and control the map selection via that... what do you think? |
But every ECU has a wire on that pinout I believe. Its just a matter of the end user going to the ECU harness and tapping that wire. I'm looking for a wire everyone can "live without completely" and since no one needs an Intercooler Sprayer when they have Alky or water injection (most use the stock ICS reservoir anyways) there is no loss of another feature. Seeing as the non USDM IX's came with the ICS still (so I was told) I bet the ICS switch plug is still under the cup holder. Someone would have to check though.
Oh please, everyone should donate! Especially if they've ever used a feature you created,lol Its a community and god knows you do your part....times 10! Consider it a bribe from all of us to keep working on the ROM mod's if it makes you feel any better :D |
Also, I'm not sure if you mentioned whether its possible to change the trigger commands to:
connected to ground = Alt Map ON no connection to ground = Alt Map OFF |
Has anyone checked for the plug under the console yet?
Originally Posted by laramie_05MR
(Post 5088034)
I will tomorrow when I get to my shop.
