The easiest input I can think of to mimic is the clutch switch. I believe thats simply a ground/no ground switching setup in the ECU.
Alternating toggle, momentary switch can be made.
But if it gets out of step!!! |
Originally Posted by Richard L
(Post 5102419)
But if it gets out of step!!! I really wish someone made a tutorial on how to disassemble and track down a feature in the ECU. Like do a step-by-step on how to find the stationary rev limit code or something. |
Originally Posted by Jack_of_Trades
(Post 5102487)
Exactly my point :D With it set to be [ NO GROUND= alky map, GROUND= safe map] its cut and dry. With a momentary switching device, it can totally become a backwards effort.
guys we might use that free ADC input that MrFred found, setup would be like this:
ADC0F 5v = altmap ADC0F 0v = normal map I think that would provide a more stable solution, can your meth boxes emit 0 or 5V when broken/ok? |
There must be unused pin available within the many pins on the ECU?
I can use a 5V voltage regulator that flows thru a transistor to be on or off depending on the triggers from the failsafes. Write up a code on a 94170014 rom with that ADC input and I can try it out tomorrow or tuesday (paid days off :D ).
(Post 5102515)
Originally Posted by tephra
(Post 5102503)
(Post 5102522)
Thats what Tephra is talking about. MrFred found one unused input that I believe all 8's and 9's have available, yes? |
Originally Posted by mrfred
(Post 5102559)
I've got it nailed for the 9, but not yet for the 8. I had to make a 30 wire harness that I used to connect to all the unused pins and test each pin one-by-one. Total effort including working my way through the ROM code and prepping EvoScan was probably close to 40 hrs. My wife is ready to kill me.
WOMEN. |
(Post 5102559)
If ADC channel ( if it is a true ADC) can modify fuel and ignition map based on a 0-5V meths flow sensor - we will have a truly ultimate close-loop fail safe.
The more meth you inject, the more aggressive the timing advance and more fuel can be taken out. Need to write a patch for the meths vs fuel/ignition trim %. |
oh yeah I know all about the Wife (Girlfriend) factor :) hehehe kinda why I havn't done anything for a week or two :)
Nice work MrFred, is ADC0F mapped to another memory variable or is it just the raw input in the code? We might as well make this the official input for mapchanging on the nonICS equipped evo's as well, to standardise it. That way people can wire in a switch to flip between maps. This week I will try and get a ROM out for someone that wants to help test this new mod, once it works then I can roll it out for other ROMID's with instructions on howto wire it up. Maybe Jamie since this is your baby? |
(Post 5102639)
(Post 5102643)
(Post 5102639)
