Help: Vista OS OK?
Old Dec 24, 2007 | 02:10 PM
donour's Avatar
Originally Posted by logic
Speaking strictly in terms of Evo tuning software:
No EcuFlash support, a long-time complaint of mine. (If Colby would release the source publicly, you'd probably see a port in very short order.)
He will give you a source snapshot if you bug him enough. I have one from mid 2006 that I did get built for linux, but the I/O code didn't work and it was _not_ stable. That was, coincidentally, the same code that I used for the Mac teaser screenshots from around the same time.
One option is libmut; while raw, it may do the job; I haven't had a chance to spend much time with it yet.
Oh it works. It's a standard autoconf/automake build system. ./configure && make and go. You can code an interface in C or any of the languages supported by SWIG (python, perl, ruby, tcl, java, scheme...pike :-p )
d
Old Dec 24, 2007 | 02:12 PM
donour's Avatar
Originally Posted by codymac
Have you asked for it directly? Curious as I recall a recent OSX port being tested by someone.
Tested? It works. I've been using it for at least 6 months.
d
Old Dec 24, 2007 | 05:56 PM
logic's Avatar
Originally Posted by donour
Oh it works. It's a standard autoconf/automake build system. ./configure && make and go. You can code an interface in C or any of the languages supported by SWIG (python, perl, ruby, tcl, java, scheme...pike )
*grin* I was only interested in the Python bindings, but good to know LPC is an option. (I haven't heard of someone using Pike in a looooong time, good times.) I'd gotten it built without any hassle, but hadn't had a chance to test it out with the cable yet.
But, this is way off-topic for the original thread, so I'll hush up now.
evo7girl
May 30, 2009 07:26 AM
ant_turbo
Mar 13, 2009 06:48 AM
cky_bam_marg
Feb 3, 2009 01:19 AM
