Accuracy of logged items
Old Jan 4, 2008 | 03:52 AM
jcsbanks's Avatar
Barometer - we use x/2 kPa. I think this is optimistic compared with the ECU map sensor using the calibration out of the service manual, AVC-R MAP sensor and with internet weather information for the prevailing barometric pressure. I think 0.495x kPa is nearer - it brings the atmospheric log readings down by 1kPa or 1% approx. Perhaps the supply rail is a little over 5V.
On the same lines - narrowband O2 - we use 0.0195x. 0.02x certainly makes it easier to read with 0.86, 0.88, 0.90, 0.92V being a typical range of full load values. If the ADC supply rail is over 5V then it will be likely nearer 0.02x anyway.
Old Jan 4, 2008 | 08:22 AM
GTLocke13's Avatar
What's the inherent accuracy of the sensor? The high accuracy stuff from Rosemount that they use in nuke plants is only 0.2%, but you're looking at $2500+ per sensor. I'll bet the reference accuracy of any of the pressure sensors we use is greater than 1% (possibly much higher). Any adjustment smaller than that is effectively meaningless.
Old Jan 4, 2008 | 08:50 AM
jcsbanks's Avatar
Agree, but if we are talking about a consistent offset between two sensors on the car measuring the same thing (MAP and Baro with engine off - whether throttle open or closed) then I think it is worth correcting as this error will probably double the error to 2%. When I last looked a typical automotive MAP sensor was <1% error, and typical 10 bit uC ADC error is <1LSB.
Maybe I'm becoming obsessed by speed and accuracy for no good reason
Old Jan 4, 2008 | 08:56 AM
GTLocke13's Avatar
Agreed that you can cal out a consistent offset. You'll have to trend it long term to make sure. Hysteresis in the sensors could have you chasing your tail.
tephra
70
Jul 11, 2024 12:59 AM
4b11slayer
Jul 28, 2017 10:33 AM
SkyNight
May 15, 2016 04:03 AM
benpgreen
Sep 12, 2010 05:12 AM
turboevo8
Sep 25, 2006 08:29 AM
