Error in tables ecuflash in idle...
Old Jan 4, 2008 | 07:40 PM
Oettinger's Avatar
-For import data, Ecuflash 1.29a or 1.31 o 1.34???
-Where is the good table??
In ecuflash idle stepper Look-up Table:
In ecuflash Desired ISCV: Is good the celsius in evo 8????
Old Jan 5, 2008 | 03:19 AM
Oettinger's Avatar
Help me Please!
Old Jan 5, 2008 | 06:29 AM
EvoBroMA's Avatar
what exactly are you asking?
Old Jan 5, 2008 | 06:40 AM
justboosted02's Avatar
seriously
Old Jan 5, 2008 | 06:44 AM
Oettinger's Avatar
Ok! Ok! Sorry, speaking very bad english, sorry!
-Ahmmm... Both tables, what is the correct?
-And down table, de celsius is correct or init valor is 20 or is -32?
Old Jan 5, 2008 | 07:38 AM
juyanith's Avatar
My Idle Stepper Look-up Table matches the first one (on the left) that you posted. The table index of Desired ISCV... also matches the table you posted, although the values do not. I hope that answers your questions.
Old Jan 5, 2008 | 07:59 AM
EvoBroMA's Avatar
how are we supposed to know which table is correct?
its not that your english is bad, it's that you're not giving us any information.
where did you get those maps? which one is which?
what year and market is your Evo?
What is your ECUID from your stock ROM?
and last but not least, why are you editing these tables if you don't already know what they are? what are you trying to accomplish?
all the tables you posted will work fine.
Old Jan 6, 2008 | 06:45 AM
Oettinger's Avatar
The table left is in ecu version JDM and right table is EDM ecu, where is the best?
And other question:
Desired Idle-RPM Neutral is Address 426c???
and
Desired Idle-RPM Drive is 427a??
Old Jan 6, 2008 | 09:42 PM
EvoBroMA's Avatar
like i said it really doesn't matter which table you use, and i still don't know why you're messing with them if you don't know what they do. they're different because you're in a different market, with different weather, and preferences. use either one, you will not know the difference. or better yet, use the one that was in your original rom.
And other question:
and
your scaling is screwed up. if you fix it you will see the value in proper RPM and not hex.
those 2 values are for idle for when the car is in neutral either rolling or stopped. the names are misleading.
Old Jan 7, 2008 | 02:08 AM
Oettinger's Avatar
OK! very thanks!
raytrix
Mar 15, 2011 01:34 PM
beyonddc
Feb 19, 2009 05:31 PM
acidandroid
Mar 9, 2008 12:19 PM
Lancer EVO IX
Aug 29, 2007 06:02 AM
Lancer EVO IX
Oct 8, 2006 03:34 PM
