Scaling Injectors SUCKS!!
Old Jan 14, 2008 | 07:20 PM
RazorLab's Avatar
Glad I could help indirectly.
Old Jan 14, 2008 | 07:35 PM
Wicked E's Avatar
Well it sucks for the people that had to do it FOR us to use...
Thanks again Razor... that was mighty nice of you to post...
Old Jan 17, 2008 | 07:02 AM
Tuky's Avatar
Here's a tricky one... (at least for me)
Currently I'm driving a Mitsu Airtrek, that comes with a detuned Evo 7 engine.
It comes with 420cc injectors from factory (high impedance), I've changed it to 520cc injectors (Evo 8), also using a resistor box (since those injectors are low impedance). Would it be correct to use the Evo 8 values for injector scaling and voltage latency? I'm a bit lost on the voltage part, not sure is the bloody resistor box might play a role in between...
Airtrek figures
Injector scaling: 424
Voltage latency
4.6875 6.12
7.03125 3.96
9.375 2.136
11.7188 1.272
14.0625 0.744
16.4062 0.36
18.6768 0.096
Evo 8 Figures
Injector scaling: 513
4.6875 3.312
7.03125 1.68
9.375 1.032
11.7188 0.672
14.0625 0.432
16.4062 0.264
18.6768 0.144
appreciate the help...
Cheers
Lucas
Old Jan 17, 2008 | 10:30 AM
Wicked E's Avatar
It would seem to me that you would want to copy the factory evo 8 map for latency and voltages?
That would be the easiest way to do it and then fine tune it from there.
Cheers-
Erich
Old Jan 17, 2008 | 01:38 PM
PlanoEvo's Avatar
RRE tune that came on the car (which was half-assed)
Once again an example a DSM tuner tuning a EVO.....
Old Jan 17, 2008 | 03:17 PM
Wicked E's Avatar
Not sure if this is sarcasm or serious, good or bad?
Hard to tell on the internet...
Old Jan 18, 2008 | 02:27 AM
Tuky's Avatar
This clearly shows that you don't have a clue... go and play with your car, that might help you.
Old Jan 18, 2008 | 04:24 PM
PlanoEvo's Avatar
Actually I do and I was relating to a previous post about a DSM tuner(Scott Grey) at RRE that tuned a fellow evom car and tuned the mivec map and it was even worse than the stock map and yes he paid for this half *** tune.
https://www.evolutionm.net/forums/sh...d.php?t=303845
Old Jan 18, 2008 | 04:31 PM
Wicked E's Avatar
Do you happen to know that member's real name? Reason being, I am trying to locate the original owner of this car...
Fast_Freddie
Oct 30, 2023 01:56 AM
teribble
Jan 31, 2017 08:22 AM
EvoIXPilot
Mar 19, 2013 07:26 AM
Raceghost
Nov 28, 2012 04:32 AM
babaz7
Jul 6, 2012 06:35 AM
