Knock on deacceleration??wierd
Old Jan 27, 2008 | 12:39 PM
xpro's Avatar
can someone please tell me,on couple of runs every time i log knock count i seem to get up to 10 knocks every time i let of the throtle.my timing seems to be fine but its wierd that every time i let offthe throtle i get good few knocks logged.
Would the dumpvalve noise maybe affect the knock sensors?
BTW, my evoscan wont let me save the logs so i cant upload the but only view them.
any ideas there?
thanks
Old Jan 27, 2008 | 12:40 PM
scorke's Avatar
Could be something/anything that is physically hitting the engine or undercarriage when you let off the throttle.
See if you can use map tracer and see exactly where its occuring, drop timing in those zones severely and see if it clears up or goes away, if it doesn't its knock, if it does its artificial noise coming through as knock.
Scorke
Old Jan 27, 2008 | 12:43 PM
dsmjeffro's Avatar
check your down pipe make sure its not hitting the oil pan or transfer case i had this problem
Old Jan 28, 2008 | 01:15 AM
Pd1's Avatar
Pd1
This can also be caused by backpressure. The exact same thing was happening when I was experimenting with the stock cat-back. Try reducing the timing values at the load cells that you're hitting when you lift the throttle. If it's something physical causing noise, you'll still get the knock counts. If you reduce your timing values and the knock reduces/goes away, then you know it's actual knock.
Old Jan 28, 2008 | 08:22 AM
spdracerut's Avatar
search under 'lift throttle knock'
Old Jan 28, 2008 | 08:23 AM
Billy@EnglishRacing's Avatar
what clutch do you have? and condition of said clutch?
Old Jan 28, 2008 | 10:28 AM
lemmonhead's Avatar
yup lift off detonation, except 10 seems kinda high, I was only seing 1-2. You can change your open loop maps to help that knock out without having to reduce timing. But as the guys mentioned, that much knock sounds like something is phycically banging around.
MyronGainz
Jun 5, 2013 05:10 PM
10isace
Sep 20, 2010 09:48 AM
casper980
23
Jan 10, 2009 07:38 AM
dudical26
Jul 26, 2006 05:59 PM
racegate
AEM EMS
Jul 17, 2005 01:35 PM
