problem with ecuflash 1.34
Old Feb 17, 2008 | 06:32 PM
Cyloc's Avatar
Question problem with ecuflash 1.34
I just downloaded ecuflash 1.34. I can not connect with the evo viii that I am trying to flash. I think it may be the program. But I am not sure. I can log the car just fine with both evoscan and mitsulogger.
But I can not read or flash to the ecu. Does anyone have any ideas that would help me fix this.
Old Feb 17, 2008 | 06:35 PM
sharkm87's Avatar
does it show the icons to read or flash??? or they aren't there?? when my icons weren't there it was because it had to reinstall drivers for that version.
Old Feb 17, 2008 | 06:42 PM
Cyloc's Avatar
It shows the Icons. It then gives me an error message that says the interface failed. I think the cable may be broken. I know the big cable allows you to log and the smaller on, tells the ecu to let you read and write.
Old Feb 17, 2008 | 07:11 PM
sharkm87's Avatar
there are pins bent??...well have you tried using an older version of ecuflash?
Old Feb 17, 2008 | 08:24 PM
codgi's Avatar
Try with another cable. Since the logging part of the cable is working there is a good chance the flashing plug is just busted.
Old Feb 17, 2008 | 08:28 PM
03RRVIII's Avatar
you need an ECUunlocker to acces it!
heres the link:
http://www.aktivematrix.com/forum/dl...gory&cat_id=11
open the unlocker 1st, before the ECUFlash............
Old Feb 18, 2008 | 03:26 AM
Cyloc's Avatar
already tried the ecu unlocker....nothing
Old Feb 18, 2008 | 10:07 AM
G20's Avatar
G20
you may have the universal cable (the one that suppose to work for both Mitsubishi and Subaru) which doesn't work with EcuFlash above 1.29a for some reason.
I just helped my friend reflashing his evo last week and that is what happened. I have the Mitsubishi specific one and it works great but his universal wont but it worked on older version 1.29a.
Old Feb 18, 2008 | 02:49 PM
Cyloc's Avatar
Is There A Way To Get 1.29
Old Feb 18, 2008 | 03:43 PM
kreionic's Avatar
http://www.openecu.org/index.php?tit...ash&oldid=1543
Old Feb 18, 2008 | 06:36 PM
Cyloc's Avatar
G20 and Kreionic........Thanks for the help. Kreionic the link did not work. I was able to get a copy of 1.29 anyway. Version 1.29 worked.
Old Feb 18, 2008 | 06:40 PM
kreionic's Avatar
hmm link works for me
Old Mar 19, 2008 | 06:48 PM
laramie_05MR's Avatar
i am having a similar problem. i downloaded 1.34 and the icons are not bold. i reinstalled and the samething.
lonestarevo83
Jul 15, 2011 07:20 PM
ohEVO18
Aug 20, 2010 07:32 AM
4mypsp
Apr 30, 2010 12:27 PM
Mitchubishievo
Apr 28, 2010 09:04 AM
GTijoejoe
Aug 20, 2009 06:24 PM
