need input on evoscan logs.
Old Feb 18, 2008 | 07:20 PM
4g63_guy's Avatar
still learning what to do with ecuflash and wanted to get others input on the logs i have.
File Type: zip
Old Feb 18, 2008 | 07:24 PM
EvoDan2004's Avatar
i would at least set it up in a better order.
Old Feb 18, 2008 | 07:49 PM
4g63_guy's Avatar
what exactly do you mean in a better order? i just saved my logs from different days but same settings for all of the logs. the only thing that is different would be air temp
Old Feb 19, 2008 | 01:17 PM
lemmonhead's Avatar
he means the arrangement of the columns.
you should put your stuff in this order
throttle rpm load timing a/f ratio 02 airflow coolant temp
it just makes it easier to read.
Old Feb 19, 2008 | 01:40 PM
Mellon Racing's Avatar
it's hard to say....nb02 and done with too much time inbetween runs. there's a few counts of knock cropping up here and there, nothing ugly though.
Old Feb 19, 2008 | 04:11 PM
RazorLab's Avatar
That big ol' boost spike is making things hard for you I would imagine. Do you have the solenoid side pill out?
Old Feb 20, 2008 | 03:53 PM
4g63_guy's Avatar
I still have the solenoid side pill in there. could change in weather play a big factor as far as spike or altitude
Old Feb 20, 2008 | 04:53 PM
RazorLab's Avatar
It shouldn't spike like that at all. Did you get the pill itself or the whole assembly?
I wonder if the assembly got damaged?
mines5
Oct 8, 2016 11:28 PM
danfalcas
Aug 9, 2016 07:49 AM
rxtec
May 2, 2016 05:13 AM
evo jason
Jan 7, 2012 04:25 AM
Yamahar1
Nov 18, 2010 06:07 AM
