whats so special about 96940011?
Old Mar 20, 2008 | 03:29 PM
  #121
scheides's Avatar
EvoM Moderator
*cough* *cough* nudge nudge
Old Mar 23, 2008 | 07:25 AM
  #122
scheides's Avatar
EvoM Moderator
Please razorlab try out this last ditch effort, I'm trying to be patient but its just a quick test and it's been almost a week now....
Old Mar 23, 2008 | 07:31 PM
  #123
tephra's Avatar
you could try it...
RL has already mostly verified that its not going to fry anything!
Old Mar 23, 2008 | 09:26 PM
  #124
scheides's Avatar
EvoM Moderator
Send it on over, I'll give it a go. chris@snowsecurity.com, or pm me a url?
Old Mar 23, 2008 | 10:10 PM
  #125
tephra's Avatar
its in the V5 thread
Old Mar 24, 2008 | 06:31 AM
  #126
scheides's Avatar
EvoM Moderator
Heh please tell me you just added that!
Downloaded, got my stuff in there, and I made a second one with the immob disable per instructions above. Wish me luck!
Old Mar 24, 2008 | 06:34 AM
  #127
SEEnoEVO's Avatar
Awaiting the results
Old Mar 24, 2008 | 07:15 AM
  #128
rish197's Avatar
What the heck, I'll try it too. Can't hurt to have a 2nd (or 3rd) set of eyes.
Old Mar 24, 2008 | 07:46 AM
  #129
rish197's Avatar
FYI - MY CAR STARTED RIGHT UP!!!!!. Haven't had a chance to go around the block yet, but this is a good sign!
Old Mar 24, 2008 | 08:07 AM
  #130
agron25's Avatar
What is what your engine lights CEL, the it when it works
Old Mar 24, 2008 | 08:31 AM
  #131
scheides's Avatar
EvoM Moderator
^try a little harder on the english there frenchy, or just post in french and I'll translate
I loaded it on my car, and initially it would just turn over and do nothing. With the immobilizer disabled, it would stumble for a moment like it was going to start, then just die instantly. Any idea on what I can test to get it working? I disabled all of the valet and auto-valet stuff, copied immob code, etc, but no luck
rish197, you have a 2005 MR, right? My car is a GSR w/ SSL, wonder if there is a difference between the two....
Old Mar 24, 2008 | 08:38 AM
  #132
scheides's Avatar
EvoM Moderator
what did you do with your valet rev limit? With it left standard (114rpm) and all of the valet options disabled in the Mod Options area (Enable Auto-Valet = 0, Enable Valet = 0) the car would simply stumble and not start. I will raise the valet rev limit value to 3000 and see if this helps.
Old Mar 24, 2008 | 08:52 AM
  #133
rish197's Avatar
I disabled all of the "Mods" just to see if it will fire up, and it did. I am in the process of enabling everything, on at a time to see if anything fails. So far *knock on wood* no CELs.
Yes I have an 05 MR. Not sure what if anything would be different. I was using the 96940011 rom before.
Old Mar 24, 2008 | 08:57 AM
  #134
scheides's Avatar
EvoM Moderator
Ok, post up with successes or if you reach a stumbling point.
Old Mar 24, 2008 | 10:06 AM
  #135
rish197's Avatar
Okay, just got back from trip....
Seems like everything is running. Did a few WOT runs, and didnt have any explosions I had the Valet mode, and AutoValet work fine. I got the slow and fast Knock light to show.
Didnt enable the alt map yet, but I have the cable, and will try to install tonight.
Also didnt try the NLTS yet.
