Boost Cut/ Spike
Old Feb 25, 2008 | 01:01 AM
prEVOke's Avatar
Boost Cut/ Spike
I have a JDM IX, just fitted a 3" TBE and under acceleration the car is hitting boost cut, it builds then cuts out for a second, which causes a jolt, then re spools, then cuts again.
I presume this is down to the boost spiking due to a decrease in exhaust back pressure. Now i have been tickering with ECUflash, but since i just got my exhuast i haven't made any changes other than the RS VVT map and i haven't got a wideband yet so wouldn't fncy having a play until that is purchased and fitted.
I will be fitting my HKS EVC VI in a few weeks, but what safe ammendments can i make to the ECU parameters in order to eliminate the boost cut?
Much appreciated
Old Feb 25, 2008 | 01:56 AM
tephra's Avatar
Boost Limit table!
do a 2byte load log of your car to see what loads you are hitting then adjust the table accordingly.
if you have a map sensor do a log of that as well to see how much boost your hitting
Old Feb 25, 2008 | 06:35 AM
prEVOke's Avatar
Thanks tephra i'll try and have a look this evening,
Boost limit is already set at 260 accross the rev range, with regard to that value how wrong am i in assuming that it's meassured in bar so does that mean when it spike to 1.6bar it's cutting? I dont want to remove the protection as i assume again that is in place to protect the car from running lean so what sort of parameter can i set it at that will enable me to still have a safety margin in place?
Old Feb 25, 2008 | 02:17 PM
tephra's Avatar
nah it doesn't really correlate to psi/bar, do the 2byte load log to be sure before you up it.
Old Feb 25, 2008 | 02:33 PM
Mellon Racing's Avatar
or simply bump it up 5 at a time until the problem goes away but monitor knock to make sure it's safe where you're allowing it to go.
Old Feb 25, 2008 | 05:54 PM
cossie1's Avatar
As a guide ralliart ecu's set the boost cut to 319% on e7 roms
So I'd guess if you upped it to around 300% it should stop you hitting the boost cut for now
Old Feb 25, 2008 | 10:37 PM
codgi's Avatar
This basically disables the boost cut all together. This isn't really safe since if anything ever goes wrong you've just lost another safeguard.
Old Feb 25, 2008 | 10:50 PM
tephra's Avatar
agreed, best thing to do is tune and log your boost+associated 2byte load then add 20 and put that into the table.
Old Feb 25, 2008 | 11:02 PM
cossie1's Avatar
If he is already at 260 and is hitting the cut, then it would need to be around 280 anyway, so by setting it to 300 thats adding the 20 that you suggested ???
Old Feb 26, 2008 | 01:58 AM
tephra's Avatar
well if he is hitting 280 then he should probably check his boost, hitting loads that high and not knowing it is dangerous..
Old Feb 26, 2008 | 04:27 AM
burgers22's Avatar
OPs car is a JDM Ix so he can log boost easily. 260 is way low for that type of car, 1.8 Bar will see you around the 280 mark so a boost cut of 300 is pretty sensible.
MB
Old Feb 26, 2008 | 04:36 AM
tephra's Avatar
Originally Posted by burgers22
18 Bar
WOOA BABY!
you need some 30mm head studs to hold that sucker down
Old Feb 26, 2008 | 04:43 AM
burgers22's Avatar
He he, i've edited in the point now!
MB
Old Feb 26, 2008 | 07:07 AM
319kpa doesn't disable boost cut, it's still a 319kpa...I found out with the HTA 35R @ 30psi on pump gas
you have to bump up the delay timer too to truly disable boost cut.
Old Feb 26, 2008 | 08:25 AM
cossie1's Avatar
MB
Thanks MB, I didn't think I was going too over the top, when I said 300, however I didn't have any sleep last night, so I could have got it wrong
Nkryptd1
22
Apr 12, 2009 08:26 PM
2.0Ldoom
Feb 15, 2009 05:03 PM
XK120
Oct 20, 2006 05:33 AM
zze86
Nov 24, 2005 02:17 PM
o4whtevors
Apr 1, 2005 12:09 AM
