remote start/2step
remote start/2step
soi have a remote start on my car and my tuner told me that i am unable to have both the 2step and remote start at the same time.. im thinking its because of the clutch, and how the remote start makes the car think its there when stationary.. so wanted to know if there was a way to run both, either with a relay.. hope this is the right section for this question
thats not true...
There are two plugs for the clutch.. one will disable the 2step limiter the second disables needing to have you clutch down while starting... If you look behind your clutch youll see a little box with a button on it, follow that up and youll see a harness. Unplug that and youre ready for remote start.
Cheers!
Cheers!
so just leave the switch disconnected at all times and you can use your remote start and use your two step without any issues.
ahh! i went to "the shop" and jr tunned it for me.. he does have really good pricing but i didnt like a few things about how they did business.. because i have a 05 evo (5000 limiter) and after i got the remote start put in, the limiter seemed to never work after that.. but would this be a tunning problem?
+1 on different tuner dude, got 2 step and remote start here also.
BIG THING TO REMEMBER..........ALWAYS PARK AND LEAVE YOUR CAR IN NEUTRAL. THAT WAY U'LL AVOID NASTY SURPRISES
Your remote starter should prevent any nasty surprises if it is setup properly for a manual transmission car.
yeah i make sure i never leave my car in 1st ever.. i really gotta see if i have a neutral safty switch so even if it did it wouldnt move.. but damnt! i want a 2step even tho it may kill my stock clutch a bit faster hehe
