Problem initializing ECUFLASH with car!!!
Old Mar 5, 2008 | 04:50 PM
mitsuboost30's Avatar
I obviously did all the appropriate steps.. ignition to on pugs in.. I even tried the ECU UNLOCKER... Says ECUFLASH is connected but wont read from the ecu.. is anyone else having problems with connecting to a 9 ecu?!?!?!? Anyone have suggestions.. pointers tips ANYTHING..
Old Mar 5, 2008 | 05:00 PM
mifesto's Avatar
this sounds silly but i hope your batter is fresh. i've encountered this issue once when connecting with ecuflash
Old Mar 5, 2008 | 05:01 PM
My battery??? im hitting 11.8v.. u think i should charge it?
Old Mar 5, 2008 | 05:04 PM
20psiMR's Avatar
Had this happen last night actually, scared the crap out of me lol. I had a bad flash, had some xml that was wrong. Couldnt flash the car back and it wouldnt start either. Tephra suggested to put your key in but dont turn it to on position. Get ecuflash ready, hit your read or write button, and when the connection box pops up dont press it. Hover your mouse over it, then turn the key and click the box at the same time. This way ecuflash is trying to init before the ecu does anything else and it worked for me.
Old Mar 5, 2008 | 05:05 PM
20psiMR's Avatar
nm ya battery is problem, you posted right as I did. Car needs 12 volts to start, and writing to the ecu takes some voltage. Charge that bish.
Sounds like something that would prob happen too me i will try it out now.. be back with results
Old Mar 5, 2008 | 05:07 PM
ok will try it out
Old Mar 5, 2008 | 05:15 PM
mifesto's Avatar
or if you have a trickle charger, hook it up before connecting the ecuflash to make sure u hit 12v
Old Mar 5, 2008 | 05:24 PM
Nah i only have the typical plug into wall charger.. its connected now and chargeing.. gonna give it an hour
Old Mar 5, 2008 | 06:10 PM
That worked thanks guys!!
Old Mar 5, 2008 | 09:14 PM
evo8426's Avatar
i know your problem is solved but sometimes if its cold like 30-40 degrees it will not allow you to flash the car atleast thats how it is for mine
mmixan
Sep 17, 2011 04:29 PM
Werd
Jul 19, 2009 12:38 AM
markymark1082
Jul 15, 2008 10:33 PM
06ravenmr
Jun 29, 2008 06:09 PM
Cyloc
Mar 19, 2008 06:48 PM
