Trouble Logging 2byte Load
Old Mar 10, 2008 | 07:27 PM
evo8426's Avatar
I'm having trouble logging 2byte load in EvoScan since I added the tephra patch NLTS+Valet+CEL to my rom. When I use a different .hex without the patch I can log it and get correct values but it is giving me numbers in the 8000's up to 20000. I'm not sure what could be wrong
EDIT: Now that I've tried going back to a different .hex it still logs those same values
Old Mar 10, 2008 | 11:53 PM
JohnBradley's Avatar
You added the 2 byte values from your old rom to the new Rom? Which one is it?
Old Mar 11, 2008 | 04:48 AM
evo8426's Avatar
I could and was logging 2 byte before the patch and I've got a 88590015 rom
Old Mar 11, 2008 | 07:42 PM
evo8426's Avatar
still doesn't log correctly even after reinstalling evoscan
Old Mar 11, 2008 | 11:26 PM
What version of Evoscan? It sounds like the request ID's might be off or something. Hard to say though without a look at the ROM.
Old Mar 12, 2008 | 06:36 PM
evo8426's Avatar
It is version 2.1
This is what it says in Evoscan
<DataListItem DataLog="N" Color="" Display="Load MUT 2Byte Mod" LogReference="LoadMUT2Byte" RequestID="00" RequestID2="01" Eval="0.3125*x" Unit="load" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="500" ChartMin="0" ChartMax="500" ScalingFactor="1" Notes="More accurate reading than load calc." Priority="1" Visible="False" />
In the ROM for the ecu I do have what is posted in the "Official 2byte Thread" for the 88....15 ROM
Old Mar 12, 2008 | 07:40 PM
Jack_of_Trades's Avatar
Your evoscan values are correct. The 2byte values I posted in the thread were all submitted by forum members so they MIGHT not be correct. Can anyone confirm the 2byte values in THIS thread are correct for him?
88590015
2byte load
MUT 00 = 6B42
MUT 01 =6B43
2byte RPM
MUT 02 = 6B1E
MUT 03 = 6B1F
2byte AirFlow
MUT 04 = 6B9E
MUT 05 = 6B9F
MUT 3D TABLE ADDRESS = 3EE84
Old Mar 12, 2008 | 07:54 PM
Jamie, those are correct as listed.
Old Mar 12, 2008 | 07:56 PM
Thanks John.
Old Mar 19, 2008 | 11:22 AM
evo8426's Avatar
I've got the same issue again. This time there has been nothing changed in Evoscan or in my ROM file. I have no idea what is up but I removed and reinstalled Evoscan without any luck to get it to log correctly again.
Old Mar 19, 2008 | 11:26 AM
Evoryder's Avatar
same issue for me...new patch no 2 byte...i'm using mitsulogger
211Ratsbud
Jan 17, 2022 03:01 AM
roni4g63
Nov 14, 2015 11:45 AM
W2J
May 16, 2011 03:27 PM
lemmonhead
Jun 27, 2009 07:51 PM
andrewzaragoza
Feb 18, 2008 06:28 PM
