How to disable immobilizer on EDM Evo9?
Old Mar 21, 2008 | 01:44 AM
hfalex's Avatar
...mmh... maybe i did something wrong.
With 5690 the immo works and doesn't allow to start the engine.
I'll try on a different T car we have on Tuesday, and i'll let you know the results.
Old Mar 21, 2008 | 09:12 AM
inco9nito99's Avatar
Old Mar 21, 2008 | 12:19 PM
JohnBradley's Avatar
56D2...should work fine. I doublechecked the periphery spreadsheet and those values will work/have worked. Did you remember to use 0x5690 to make it enter it as a hex value?
Old Mar 26, 2008 | 11:07 AM
So pretty much if you do the rear 02 delete after the coding in the .xml file, if your periphery0 code reads 0x56DA, and if you also want to remove the immobilizer (and .xml is coded for it) you type in 0x56D0? (No immobilizer/Rear o2)? Thanks!
Old Jul 7, 2008 | 05:05 PM
ttt
Old Jul 28, 2008 | 07:30 AM
05ah8james's Avatar
im doing this with 96420007 and i cannot get it to show up in ecuflash. i did it on another rom and it worked, but not this one.
Old Oct 13, 2008 | 03:53 PM
fknlowpsi's Avatar
where exactly do i put 56D2 code?? which value in ecuflash or in XML?? if xml where exactly in XML??? sorry im new
Old Oct 13, 2008 | 09:58 PM
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
what is your init code?
the location migth be different...
00000FAA .data.w h'56DA
00000FAC .data.w h'56DA
00000FAE .data.w h'56DA
00000FB0 .data.w h'56DA
00000FB2 .data.w h'56DA
00000FB4 .data.w h'56DA
00000FB6 .data.w h'56DA
00000FB8 .data.w h'56D2
Old Nov 1, 2008 | 05:57 PM
lan_evo_mr9's Avatar
Is there a hex periphery to disable knock and immobilizer only?
Old Mar 13, 2018 | 09:12 AM
Wajeb G. Wahab's Avatar
I'm going to get this back from the dead, because I can't seem to find it anywhere as to how to disable my immobilizer or change the immobilizer on a new Rom I'm about to flash.
Can someone help, I'm a beginner and I can't see where I need to be to see all this? I already know how to use ECUflash and all just the coding part where is all that written?
Or a tutorial would do I guess...
Thanks
Old Mar 19, 2018 | 01:52 PM
todd6027's Avatar
Thanks
what do you want to do , disable immo or change immobiliser code
Igaly1021
Jan 16, 2017 11:20 AM
EvilEvolution8
May 9, 2016 12:09 PM
envdevo9
Nov 7, 2014 09:25 AM
KOOLER
Sep 22, 2011 01:31 PM
Darwinn
Mar 21, 2009 07:11 AM
