Question on Tephra Mods
Old Mar 21, 2008 | 08:10 PM
chu's Avatar
chu
I've never had anything done to my stock rom, besides the doing 2 step. Is it still important for me to copy over all of my tables to the Tephra mods table? I already know immobolizer is a must. Thanks.
Old Mar 21, 2008 | 08:17 PM
Wicked E's Avatar
yes!
Old Mar 21, 2008 | 08:26 PM
Jack_of_Trades's Avatar
Yes you do. Adding the XML info is nothing more than shortcuts which help you edit things inside the actual ROM. Unfortunately, they point to locations that only exist in the "PATCHED" ROM (.bin file) that Tephra supplied. So if you use a new PATCH, you gotta swap your info into the new ROM again, unfortunately.
Old Mar 21, 2008 | 08:33 PM
l2r99gst's Avatar
I think he may be asking if he needs to copy tables that haven't been changed at all. In that case no, but you still must use the patched ROM and copy any tables from your ROM that have changed to the patched ROM and then flash the patched ROM to your ECU.
If only the two step has been changed on your stock ROM, then just add your immobilizer, two step settings, as well as the configurations for the patch parameters to the patched ROM and flash it in.
Eric
Old Mar 22, 2008 | 01:57 AM
tephra's Avatar
I would copy them anyways, if they don't change - no harm done!
Old Mar 22, 2008 | 03:54 AM
Chamama's Avatar
^ yep, definitely copy them for safety and peace of mind. Example: ROM ID 88570008 has different maps for different cars, yet ID is same (e.g. fq360, jdm IX gsr etc)
Old Mar 22, 2008 | 07:38 AM
chu's Avatar
chu
thanks guys. I didnt want to have to go through all that, but I guess I shouldn't try to find the easy way out. I'll copy over every table.
DormantBeast
13
Jul 9, 2017 07:38 AM
FlintownKilla
Oct 11, 2012 12:40 PM
Appauldd
Sep 29, 2011 11:30 PM
nousername
Jul 18, 2011 01:26 AM
zheng0416288390
Oct 1, 2009 07:26 AM
